Fitting a Lambda sensor
Old Apr 8, 2010 | 12:06 PM
Franco's Avatar
Franco
Default Fitting a Lambda sensor
I need to fit a NTK Lambda sensor for the T6 onto my exhaust, is there a certain distance it should be away from the exhaust housing (gt30 external gated turbo)?
Can you mount them too far or too near?
Old Apr 8, 2010 | 12:13 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
The closer you can mount the sensor to the turbo, the more accurate the data you get from it is. There is obviously a delay from what happens in the engine to what your sensor sees. The further away you mount the sensor, the bigger that delay...
Normally you can mount them about 3 or 4 inches back from exhaust housing on the downpipe before it sweeps down by the bulkhead.
Just make sure you have it mounted on the top!
Old Apr 8, 2010 | 12:23 PM
Franco's Avatar
Franco
Wanted to check as was hoping I could have this done over the weekend (And Hadlands on holiday!).
manuel boeckx
13
Oct 3, 2015 02:29 PM
Dahl88
Aug 22, 2015 08:16 PM
rdvil
Aug 15, 2015 12:11 PM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
