AP brakes, which ET-value at least? (saff 2wd)
Hi folks,
I was wondering which ET-value is minimal for using (4-pots) AP-brakes on my saff 2wd.
I now have Lenso S7's with ET value 35.
Will this work?
(7.0Jx17)
Here's a pic:
Will this work?
(7.0Jx17)
Here's a pic:
Caraholic
You can't go by the ET of the wheel, it is the design / shape / thickness of the spokes that is important. Your wheel looks as though it has more clearance the further the caliper is moved out, so that is a positive thing . The only way you will know for sure is to print off the template from the AP website and use this to see if they will clear...
Thanks mate, printed out the "profile" from the AP-website.
If I understand correct I have to lay it next to the wheel to check the possibilty.
So I'll do that.
So I'll do that.
The Enigma
12-09-2015 10:12 PM
