Boot release question
Old Apr 5, 2010 | 09:36 AM
tarry500's Avatar
tarry500
Default Boot release question
Hi, just a quick Q, On the mk6 escort the boot release is on the drivers side floor but on earlier escorts its a switch on the centre console. Is it easy to convert it so its the button on the console i press rather than the horrible push thing on the floor? Many thanks. J
Old Apr 5, 2010 | 07:51 PM
tarry500's Avatar
tarry500
bump
Old Apr 5, 2010 | 09:48 PM
Iain Mac's Avatar
Iain Mac
Time-consuming and fiddly, but not difficult.
Provided the space is on your console to take the later switch it is even easier. If it isn't, you'll need to also visit Maplins or similar to get an instantaneous Push-To-Make switch.
You just need to go to the scrappy and get the solenoid from the boot (+ the switch if you are using that), then run a wire from ignition to switch so it is only live with engine off, and then from switch to tailgate where the solenoid needs screwed in and attached to the boot latch.
If you are fitting an aftermarket switch, remember to put it somewhere hidden but that you can reach easily.
boeb
Jan 9, 2020 05:11 AM
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
stevecfrst1
Sep 30, 2015 05:18 AM
