Cosworth troubles !!
hello all need your help !! urgent
i have a mk2 escort fitted with a cozzy engine turbo . just had it to msd and got the engine running sweet BUT !! only on tickover as soon as i touch the revs the engine stutters and starts to die? the engine has been pressure tested and is now all good , the fuel rail has been set to the correct pressure , all injectors , leads etc etc all tested and are good
i have also got a corsa power steering set up in it and when i unplug the ecu to the steering the alt lights come on in the dash ??!! and makes the engine stutter
msd say it is losing volts from somwhere , any thoughts or idears before i have a head burst
all idears are welcome as i have the lakes tour in under 5 weeks and need to get it sorted
cheers fellas
cheers fellas
Check the TPS is set between 2-5%
if it runs well till you touch the thottle and goes back to foot off this should be the problem like i had !
i would be surprised if the car has gone to msd and they havent set the tps up properly.
if its losing volts, is your alternator wired up properly?
the power steering shouldnt affect it
the alt will only charge if the light is off.
have you got 13v at the bsttery now? as it had less than 11v when we had it which is why we could go no further, either the alternator was goosed or for some reason not charging
i was limited to what i could calibrate at the time as the ecu was shutting down. if the charge issue is sorted, give me a ring on tuesday and i will get it back in finish the static set up
cheers mate and thanks for the replys
i would guess mate as your dash biniccle was missing the charge circuit is broken by the light missing, so when its back together it may work ok, measure battery voltage with a meter and make sure it reads over 13v,
as it is, the battery is under 11v, so this needs sorting before you go any further
it will be an ace car when its sorted mate
it will be an ace car when its sorted mate![Top](https://passionford.com/forum/images/smilies/smile011.gif)
the clocks maid it worse to start when i plugged them in [ poss drawing more power !!? ] and still wouldnt rev up, when i left the clocks plugged in i unplugged the power steering and the alt light come on ?
![fume](https://passionford.com/forum/images/smilies/fume.gif)
![ban-split](https://passionford.com/forum/images/smilies/ban-split.gif)
![bowdown.gif](https://passionford.com/forum/images/smilies/bowdown.gif)
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
Adam Graham
06-09-2015 06:04 AM
