How do I translate a PDF from French to English???
Shotgun Bunter
Not true, if it is an image send it to me and i will run the image through an OCR process and export the text into word format.
You will still need to translate it though
Shotgun Bunter
You are right Chip, OCR is not an exact science and I wouldn't even bother using the free software unless it is a computer generated original and even then S's get exchanged for 5's etc
I however do have bureau software and don't mind running your pdf through it between now and 5:30
Comment is "without cutting and pasting it into google for example???"
Does not say it can not be cut from the original text only that the convertion process to convert the original to word is proving difficult.
If it is an image file then OCR or typing it into a word doc (for example) is the only real way to achieve the end result.
nico12
31-12-2015 04:42 PM
nicos#29
17
07-09-2015 05:32 AM
