S2 NON ABS Brake Res
Old 10-01-2005, 05:20 PM
PhilM
PassionBMW.com Member
PhilM's Avatar
Default S2 NON ABS Brake Res
I have part no 6081263, which Ford say is the non ABS mk4 resevoir, looks like it......but doesnt quiet fit
The holes at the bottom are slightly too wide (1-2mm dia) to fit into the master cylinder.
Anyone know the TRUE finis for the non ABS res? or do i just need new seals in the master cylinder?
Old 10-01-2005, 05:46 PM
BODGE
BODGE's Avatar
as i said m8 it will go in as i had the same lube up the rubbers with brake fluid and push like fook
mark
Old 10-01-2005, 05:47 PM
Hardeep_Singh
Hardeep_Singh's Avatar
what about a s1 brake res phil?
Old 10-01-2005, 05:48 PM
PhilM
PhilM's Avatar
Thanks Mark...didnt get a message from you, missus must have read it and not told me...glad I have the right part, the original one goes in easy, this one is a coont!.
Theres no such thing as too much lube eh Cheers mate
Old 10-01-2005, 05:50 PM
BODGE
BODGE's Avatar
Old 10-01-2005, 05:52 PM
PhilM
PhilM's Avatar
muzzman1
30-09-2015 08:59 PM
Quick Reply: S2 NON ABS Brake Res
