escos electric windows
need help !!!
the electric windows dont work on my escort cossie.
i've checked the fuse (fine) pulled the door card off and put power straight to the motor
which works goes up and down. lol
put a volt meter into the plug which goes on to the motor pushed switch up and down and theres power there.
but with the plug pluged in the windows wont work.
any ideas.
neil
any ideas.
neil
all earthed as far as i can see.
there must be power at the switch.
like i said if i unplug the plug from the motor and connected a volt meter and then press the switch as if i was gona put the window down.
when i press the button the volts go up to about 13 volts. release the button and it goes back to 0.
then if i push the plug back on the motor press the button, nufthink
stumpped.
stumpped.
chowfornow
14
05-01-2019 09:01 PM
