How big throttle body for BIG HP?
Old 10-01-2005, 11:07 AM
Azrael
Azrael's Avatar
Default How big throttle body for BIG HP?
A guy here is building ~800HP Audi Quattro and is asking around about different BIG HP cars technical solutions. He wonders how big throttle bodies are used on eally popwerfull fords - works RS200 or 700-800BHP Cossies? Anybody know what ind of diameter it schould be?
Old 10-01-2005, 11:35 AM
turbinator
turbinator's Avatar
Default Re: How big throttle body for BIG HP?
in first.. its down to the elbow on a cosworth which is the limiting factor.
So .. in first .. on a cosworth you would need to get a custom manifold which bins the elbow...
then .. you go for a bigger throttlebody...
on a cosworth .. 65 mm from a RS500 .. (standard is 56mm)..
this is enough to go to 600 ish...
i use one from an alfa V8 (76mm)...
hope this helps..
Old 10-01-2005, 11:38 AM
Azrael
Azrael's Avatar
I know it's down to elbow, I wonder what is used on those really powerfull cars which don't have the elbow problem
What is the diameter od RS200?
Old 10-01-2005, 11:56 AM
I use a rs500 set up on mine it makes more than 600 , circa 650 @ 2.5 bar on race fuel. Then 150 Nitrous is crammed in with no probs.
Rod
Old 10-01-2005, 12:02 PM
Karl
Norris Motorsport
Karl's Avatar
Hello,
For 800bhp I would advise a 75mm throttle body with a forced induction engine. If you are using say a 650 engine + NOS as Rod does then you can get away with a smaller throttle as the base engine air flow is not effected by the NOS. In this case 65mm is adequate.
Old 10-01-2005, 12:06 PM
Azrael
Azrael's Avatar
Originally Posted by Karl
Hello,
No it was rather real 800HP drag car without NOS. Thx for info Karl.
Old 10-01-2005, 07:38 PM
GARETH T
GARETH T's Avatar
just to back up what karl said,,(not that he needs it at all)
ive read that 75mm will be fine
mk3ste
17-10-2021 10:09 AM
01-11-2015 06:53 PM
gcfcos
59
06-10-2015 05:04 PM
Brickhouse
14
03-10-2015 07:28 PM
Quick Reply: How big throttle body for BIG HP?
