Gear changes
Old Jan 9, 2005 | 03:57 PM
Dan_L's Avatar
Dan_L
Default Gear changes
Hi,
When accelerating hard in first I find it hard to get into second quickly Have any other escort cosworth owners got any tips on how to get it in second quickly, is it best to push it to the side and pull down at the same time or just pull down?
Thanks for any help,
Dan
Old Jan 9, 2005 | 04:10 PM
Alvyn's Avatar
Alvyn
straight back MUST be the quickiest change surely so I'd say go and practice your gear change tecqnic(spl) or failing that maybe your selector in the box could be worn!
Old Jan 9, 2005 | 07:23 PM
Neil S's Avatar
Neil S
Think theyre all the same mate - the synchro's in the MT75's struggle with the change from first to second at high revs
I just change more slowly and deliberately if you know what I mean...
Neil.
Old Jan 9, 2005 | 07:24 PM
St3V3_C's Avatar
St3V3_C
I have to change slower than I have in other cars
Old Jan 9, 2005 | 08:00 PM
dave cos4x4's Avatar
dave cos4x4
i found it better after i fitted a quick shift kit.
Dave.
Old Jan 9, 2005 | 08:33 PM
xr4x4rs's Avatar
xr4x4rs
synchro is weak mate
i went through 3 reconed boxes doing that
in the end i gave up
but quickshifts do help a lot
Old Jan 9, 2005 | 10:52 PM
Gaaables's Avatar
Gaaables
mines the same
Old Jan 9, 2005 | 10:55 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Yeah, a B&M Quickshift would improve things and co-incidentally I can supply this!!
Old Jan 12, 2005 | 10:28 PM
Dan_L's Avatar
Dan_L
Thanks for the replies guys I'm not sure if it is a problem with my box which is making it worse but I can never seem to get it in gear quickly and by the time its in the turbo has to re-spin up, how much am I looking at for a quickshift kit? Another prob I have is when accelerating hard and putting it in 3rd there is often a crunch noise, could these be linked?
Dan
Old Jan 13, 2005 | 02:39 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
sounds like the syncro rings are worn, try speaking to bernie , other thing to try is double clutching, ,ie as you come off the throttle dip the clutch as you put the lever from 1st to neutral, then quickly release and dip the clutch again as you engage second. Feels dead slow at first, but with practice its dead smooth and quick , and makes horrible boxes change well
do you have probs coming down as well, i.e 4th to 3rd etc etc? if you do try to match the revs to the lower gear,using heel & toe as you down shift, much smoother and much less wear on the box
Old Jan 13, 2005 | 05:00 PM
Dan_L's Avatar
Dan_L
Thanks for the advice mate, ill give that a try
tankybaby66
Feb 6, 2016 02:24 PM
The Youth.
Sep 30, 2015 09:59 PM
dojj
Sep 29, 2015 10:32 PM
cameron2
Sep 23, 2015 06:31 PM
