Fao msd mad nms chip and any other mapper
i thought this would be a better approach to my query.
have any of the tuners experienced mapping with rp / delphi / rochester injectors petrol turbo engines ?
and are they any good ?
im hoping there similar to siemens ?
thanks
thanks
*** Sierra RS Custard ***
Rod used to run 96lb rochesters IIRC, as im fairly sure the ones I got off mark were the same spec as the ones that Rod used, not sure what his new ones are though.
Have been fine for me so far but Ive only done a couple of thousand miles on them in the nova and they seem still at this stage.
the Ł400 saved will pay tr racing to fit them and map it.
well thats all good as ive found out rochester 96lb is the same injector as delphi 96lb there 17113744 injectors and if rod ran them they must be ok . Ł250 for 6 from usa. if tr racing have an injector flow tester then its worth a shot i reckon, sards / densos are Ł650 !
Flow test them as I found the quality to be crap, many sets diff and lots of mix macthing to make them work,
I refuse to use them now.
Mark
which 1000 cc injectors would you use mark on an rb26dett low imp peak and hold type, what about bosch 0951000 1000 ccs ?
thanks mark, stu and chip.
what about these in your opinion
http://cgi.ebay.co.uk/6-Nissan-Skyli...item518fe97be2
wheelwizardrefurbs
18-09-2015 08:59 PM
