What generator to run Caravan/motorhome
Rock Out!!
It really is a bit how long is a piece of string... with gennys the bigger the better, but it is down to your space, noise limitation and budget! anyting above 1kw will be ok, but 2kw to 3kw would be better. work out the max number of things likely to be going at once and then work out the draw. a normal kettle for instance can pull 2-3k in a spike.
Things will still work with less power, but take a long time..I know, when I had to wait 20 mins for a 4 min microwave dinner to do
Rock Out!!
or as the op says..he's going racing. How long before the van is full of handy air wrenches and compressors.
Like said really , big batteries and solar panels on roof to recharge them , no need for genny , im sure what you'd spend on a genny you could get a couple of good solar panels and some spare batteries and you can have peace and quiet at the end of the day , no hum from genny for you or your neighbours .
It'll offset your carbon footprint while racing lmao
havent figured out how to use it all yet
i have a larger battery underneath. must figure out how to use it all lol
DAN@ADRIAN FLUX
37
20-09-2015 10:38 AM
Eigdoog
13-09-2015 05:46 AM
