Cossie Dipped Headlight Not Working
car went for mot yesterday and failed on o/s dipped headlight, why has this stopped working? ive cleaned all the earths and fuse's are fine. main beam works fine and dipped light on the n/s works fine. anyone know what wire controls the dipped beam on the plug that connects to the headlight? just wondering if i can trace the wire to see if there's a fault.
first you need to check if you are getting power to the connector above.
1 live is for dip beam and there is another for high beam. but they only work 1 at a time. (so 1 goes out when the other comes on)
i had the same problem as you. checked all fuse's and they where fine but i swapped a fuse round by mistake and found the fuse was'nt working properly but looked ok.
09-10-2015 07:38 PM
Palethorpe01
15
18-08-2015 06:09 AM
COSWORLD
14-08-2015 07:40 AM
Escortdriver1
31-07-2015 02:36 PM
