Mondeo tdci problem
i have a problem with a 130bhp tdci mondeo 02 plate . the glow plug light is flashing and the car struggles to start first thing and smokes . i have had it on a code reader which came up with cylinder 4 injector high knock level . so i replaced it with a new injector from fords and recoded it .wipe all codes from car and run car but still does the same and the same code as well hih knock level on cylinder 4 injector. just wondering anyone else had the same just dont wanna waste to much money on the car as its not worth it
any help would be greatful
Spelling Club King!
Chasing Radders
As Dan said....get a Delphi agent to do a "Proper" recode on it..........
My Mondeo 130bhp TDCi went to Delphi HQ last week and they ran 2 different recode software on it to check there equipment....The first one said it had recoded the injectors.....Then they plugged in the all singing and dancing Delphi software and the injectors were showing the OE cycle counting still....so hadnt recode them, just reset them.....
Spelling Club King!
Which is what most recodes do! They just convince the ECU that it's got new injectors, so the ECU can't then compensate for wear etc.
People are very keen to shout 'recode' whenever a TDCi has a problem, but in reality the recode is something you do after you've fixed the car.
it was done with a snap on solus pro reader i was told this can do it
plus the car went into fords 6 months ago with the same problem and it came out with them saying no fault codes and charging 200 quid for that answer . then the problem went away and has just come back
Spelling Club King!
Hmm, have no personal experience but some of the people in the know suggest that you should only use the correct kit.
Your first problem could have been the same injector and the Ford recode (or ECU update) just delayed the innevitable, and now a different injector could be at fault. It's an arse but it seems to me that all the injectors need testing if you suspect a fault with one. They do seem to fail at around the same time as each other.
Fault codes seem to mislead as much as they pinpoint the problem, as an error with part X could affect part Y which reveals the (wrong) fault code.
