hi spec brackets/bells
I've been offered a set of monster 6's and 355mm discs, but they have come off an impreza.
Are brackets for cossies readily available from hispec, and any idea on the costs?
And do i need hi spec bells, or will any 4x4 bells work?
Cheers!
Cheers!
Being available at HI SPEC and actually getting them are different things, they can be very slow.
If it's his calipers then yes he will do the brackets, would imagine around £40-£50 mark, any bells will do that have the correct dimensions, as Geoff uses a fairly std pcd on the bells for the disc retention.
