How do I properly/legally reshell a car???
Have a couple of projects in mind, and both would involve reshelling a car.
My question is, how do i do this properly, if i want to change the ID.
-Option 1, cheap 60k mile mint base model saph locally has come up for sale, car is cat C but just with a damaged bumper, no damage to anywhere else at all. Can i strip this and use a cossie ID on this shell, Vin plate and chassis number????
-Option 2, project car, unregistered shell, how do i go about registering it and making sure it doesn't go on a Q (doesn't have any numbers stamped anywhere.)
Any help appreciated as it's not something I've done before, and if you can please excercise some restraint as I've seen threads similar to this on here before and they've just turned into a bitchfest.
1, Just reshell the car and use the ID from the new shell
2, buy a shell with no number stamped in the floor and use the ID from the rotton car
3, Sell the rotton car and buy a good one , lol
Ps, you do dealise you are going to get loads of fools who will reply on here who havent got a clue what is legal etc telling you that whatever you do your ringing it , lol
Thanks for the help, i know I'll get lots of conflicting reports about what is legal etc,but i guess that's all part of the fun.
So how do i go about stamping the numbers on the floor etc???? And do i have to declare it to the DVLA/VOSA folk???
The best option would be to find a decent saph cosworth rolling shell and then swap the bits overs from the rotten saph cossie into the rolling shell
most will not want to buy a normal saph with cosworth running gear, as you'll get people saying "its not got the cosworth ID"
ps. there are hundreds of cossies out there with a sketchy history, people doing exactly what you are trying to do now
sadly some people think a cosworth shell with just a axle and wheels is still worth Ł1500, whereas a normal saph shell is worth Ł150
How is 1 ringing you are using the id that the car has had from new ( ie, buy a good second hand cossie shell with ID and swap everything over and use the ID from the new donour shell )
And i never said , NEW , unstamped shell
Ok think I understand now....
So in short I can't put an ID on an already registered shell that has an ID. I wouldn't want to lose the "cosworth" derivative oon the V5, so i guess the base model shell is out the window. But it's perfectly ok to use the ID on any cosworth shell as long as it doesn't already have a number???
The only true 100% legal way following the letter of the law is to use a brand new shell supplied direct from the manufacturer or their agent with a proper receipt to prove.
Once built it then needs to be inspected by DVLA and stamped by them, or in front of them usually by the police.
Everything other than that becomes greyer and greyer legally depending on which route you take.
You can ring the dvla one day and ask them a specific question, then ring the next day, ask exactly the same question and you will get a different version of the answer.
Do dealers do the above when reshelling a car - no, they usually leave it blank.
Are the police interested in what happens with just one car, generally no.
Resident Wrestling Legend
just use the shell from the donor car and fit the cossie runnign gear to it
all you do then is tell the insurance compnay and the dvla that it's got a different engine in it and job jobbed
as long as you keep the reg number of the donor car and the numbers are the same, it's been modified from an insurance comnay point of view so that might cause some greif but it'll still be legit on the dvla database and the log book will still say "not a cossie but a base model" on it
ou "could" go and tell vosa that you have a car that has a rust problem and that, due to there being a scarcity of newly available shells, would you be able to use the shell from another car and have the chassis numbers etc changed on the paperwork to show that the original car has been reshelled at some point BUT keep the original id and plates etc from the cossie, with a new set of vin plates being sent out to replace the original ones
at least you are asking the right peole the right questions
I dont really see the problem with transfering vin numbers etc, as long as your honest if/when you sell then whats the problem.
If people want a genuine one they will stay away others might not mind, i mean its not like the car is stolen or anything.
Perhaps be prepared (if your being honest) to sell the car for a little less than you would do if it was genuine.
option 1 in the original post is technically ringing but "ringing" is allways associated with one of the cars being stolen.. suppose that is from back in the day when every other xr2/3 was ringed lol
I had to re ring an xr2 for a m8 once, the fooker had 3 chassis numbers on it when he bought it!
steve
*** Sierra RS Custard ***
Its not ringing if you leave the origonal numbers in the shell you intend to use tho and just put all your running gear etc into it ,
Only dodgy if you swap the numbers from your rotten / damaged shell into the used other shell
We all say this and that tho but i would bet that there is a massive amount of people on here that have either reshelled a car or bought one knowing it has been shelled and i bet they didnt give a fook
As said above we can all talk shit about it but its only ringing if one or more of the cars is stolen
The police dont give a shit about 20 odd year old fords there only intrested in new cars having there ID swaped about
Ringing (signal), unwanted oscillation of a signal, leading to ringing artifacts.
Ringing (medicine), a ringing sound in the ears;
Bird ringing, using numbered small metal leg rings to track birds;
Ringing (telephony), the sound of a telephone bell.
had quick look but couldn't see on dvla site etc for info on what is classed as ringing
Its illegal to misrepresent the identity of a motorvehicle, and the slang term for doing so is ringing.
Cant see what you find so confusing about it TBH
In the same way I would says its illegal to nick things off someone, or to kick the shit out of them, but its not the term that a court would use in either case, it would be theft and assualt.
so that would be the charge?
and what would be classed as motor vehicle, the shell or engine or both or the other parts?
it if you changed the gear box would that misrepresent it?
as far as i know if you buy a base model sierra and take the id out and replace with cossie id its classed as ringing wether its stolen or not, as you basically have altered the veichles original id as it isnt that car the id came from
to do it properly is buy a decent 2nd cossie shell and put your stuff in it and use the new shells id
or
buy a brand new shell with reciept from manufacturer and transfer all your stuff from old shell, then it would go to vosa who will inspect the car and stamp numbers in the strut top and as long as you use a certain percentage of the old car you will get to keep your origanl id
or
you got it right there, according to the sva which deals with such cars a certain percentage of the oringal car must remain, therefore it is legal to swap a shell over and use the rest of the orginal car and not classed as ringing
http://www.direct.gov.uk/en/Motoring...cle/DG_4022107
It even mentions the word ringing, although is more in the context of stolen cars obviously as like mentioned in this thread this is the thing they are most bothered about.
If you change enough of the parts of a car, such as engine/gearbox/suspension away from the parts type approved for that car, you then get into an entirely different issue with the car no longer being type approved as a result.
Any vehicle altered in such a way after 1998 needed an SVA, although more recently this has become an IVA
So for example Charlie's focus would have needed an SVA/IVA to be legal as a road car, and so would my nova if I built one now.
You can read about the IVA here:
http://www.direct.gov.uk/en/Motoring...le/DG_10014246
Ringing is taking id from one shell and using it on a shell which has previously had its own id and its not legal
( the caveat is of course local VOSA centres who sometimes do the weirdest things! )
How can a thread go on for so long about something so simple?
from the directgov website
so re shelling is legal there...
some more info there.
http://www.direct.gov.uk/en/Motoring...le/DG_10014199
When applying for a VIC you'll be asked to declare whether your car’s chassis or monocoque body has been replaced or modified in any way. The information you provide will enable VOSA to decide whether your VIC application can proceed or whether to refer your car to a DVLA local office for inspection, where it'll be assessed in line with DVLA’s rebuild guidelines instead.
Scoring components
The following values will be allocated to the major components used:
chassis or body shell (body and chassis as one unit - monocoque ie direct replacement from the manufacturer) (original or new) = 5 points
suspension = 2 points
axles = 2 points
transmission = 2 points
steering assembly = 2 points
engine = 1 point
Where there is evidence that two vehicles have been welded together to form one (ie 'cut and shut') a 'Q' mark will be allocated, IVA, ESVA, SVA or MSVA will be required.-
axles = 2 points
engine = 1 point
vosa would not stamp numbers into cars, dvla will give you a vin in rare circumstances but they wont stamp it
