Goodridge fuel hose fittings..
Right guys,
I've bought a single Goodridge aluminium fuel hose fitting off eBay.co.uk but there's a problem,the item was advertised as a -8 fitting but now that i've got the bit it looks too big to fit onto a Cosworth fuel pump!.
Am i right in thinking that the -8 coupler has an 8mm internal feed hole?,just as stated by the eBayer,only my version he sent me has a 10mm hole,-10 by mistake??.
Thanks for any enlightment
-8 signifys a fitting/pipe in the family of hoses used in the Military/Motorsport and Hydraulics Industry...
A -8 fitting has a 3/4unf X16 threadform and the hose is 11.6mm ID
Most fuel applications usually use -6 fittings and hose....hose on -6 is 8.7mm ID
HTH
Ian
HTH
Ian
Russ Payne
25-09-2015 08:29 PM
