suspension help
Old Jan 24, 2010 | 09:43 PM
RONNIE AMIS's Avatar
RONNIE AMIS
Default suspension help
i bought a set of bilstein tarmac spec front coil overs for my 3 door and have 909 rose jointed top mounts, i bolted one together on the car today and the car sit's far too high, can i use these together? or do i need new top mounts?
any help appreciated
coil overs
top mounts
Old Jan 24, 2010 | 09:48 PM
nuttynil's Avatar
nuttynil
RS nutta
i know that 909 mounts are good but can you mount the shocks with the normal top mount might bring it down a bit but i know u want the roller top mount because they are good and you have adjusted the platforms ....Neil
Old Jan 24, 2010 | 10:14 PM
broadmoor's Avatar
broadmoor
Ron,
A gravel spec Leg/spring will be longer than a Tarmac spec leg/spring
Old Jan 24, 2010 | 10:21 PM
RONNIE AMIS
Sorry mate I meant Tarmac spec,
Old Jan 24, 2010 | 10:34 PM
broadmoor's Avatar
broadmoor
No problem...I run a gartrac mk2 escort front tarmac strut on a granada hub and just fit the strut body lower in the hub to keep some damper travel..which some people reckon is more important than looks
Old Jan 24, 2010 | 10:43 PM
RONNIE AMIS
Ha ha,
the shock body has a step in it so I couldn't do that,
Do the Granada hubs give any improvement over 3 door ones? Thought 3 door ones were ok?
Old Jan 24, 2010 | 10:52 PM
broadmoor's Avatar
broadmoor
Ha ha,
There just wider at the bottom...Which to us means we can run the wider Grp4 Gartrac strut bodie...
Your 3 door hubs are fine ..We are just stuck in the 70's and havnt moved up to 80's tech yet
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
