General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Anyone know where I can get a set of turbo water pipe washers please?Took mine off my old t38 and the washers have seen better days,Want a new set of washers to fit to my new turbo.
Many thanks.Lee.
are the water pipes same as standard mate?if so can get them from ford still!get new bajoo bolts as well!they go over to 13mm ones now!also put sealant on the seals as they are a fucker to get to seal !
It'll have standard M18 water feeds I'd imagine. Ford will do these. If not, just get hold of some copper washers from any plumbing supplies place. As long as they are about the same size.....
Doug,the washers are 13mm u say and I can get them from ford.I can also get the banjoo bolts from ford u reckon????????
Thanks.Lee.
Thanks.Lee.
na the banjoo bolt has changed from a 19 mm (i think the old ones where?) over to 13mm head!you can defo get them from fords still i got a set about 6 months ago!you also need to get some sealant to help the seals seal
