Vauxhall question- need quick answer
Old Jan 22, 2010 | 02:05 PM
Sunil_FiestaRS1800's Avatar
Sunil_FiestaRS1800
Default Vauxhall question- need quick answer
Anyone know what drive shafts you use on LET converted 52 plate Astra (mk5 i think that is?)
F20 box
Thanks
Old Jan 22, 2010 | 08:10 PM
timrud's Avatar
timrud
Mk3 Astra GSi?
Old Jan 22, 2010 | 08:19 PM
Little-AL's Avatar
Little-AL
Which LET? Z-LET or C-LET?
Can't see an F20 fitting in a Mk5 personally... you changed pedal box to cable operated clutch?
It its a Z-LET then it should be on either an F23 or a M32 - in which case shafts from an Astra VXR, 1.9 CDTi etc will fit.
If you have actually stuck a C20LET with F20 in a Mk5 Astra, you need your head looking at! Although 52 plate could be Mk4 I guess... in which case it should be an F23?
Old Jan 25, 2010 | 02:35 PM
Sunil_FiestaRS1800
Right ive brought this car now.
Its a mk4 52plate with C20LET And F20 box from what ive been told. The last owner reckons Calibra shafts are the ones to get. is there any better options??
Probably going to sell this straight on once ive sorted it, as i can see me ending up spending wedge onit to bring it upto a std id want.
tankybaby66
Feb 6, 2016 02:24 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
rsguy
44
Sep 29, 2015 03:29 PM
