powder coating
powder coating
i have a powder coated rocker cover and am wanting to paint it in 2k would i be best to have it sand blasted or could i flat the powder coat and use it as a base?
If you do decide to get it stripped make sure you get it chemicaly cleaned as blasting can cause the alloy to crack once it heats up with engine heat.
I have known one to shatter because of the heat and the swelling of the glass beads which were embedded in the alloy.
Yea agree with what peeps have said ive painted onto powdercoat before and its been fine using 2k paint, just a keyup with a bit of red scotch is usually ok.
Obviously in an ideal world its always good to start with a clean base to work from ie bare metal but isnt needed!!
