testing a throttle position sensor
Old Jan 18, 2010 | 02:03 PM
Patto's Avatar
Patto
Default testing a throttle position sensor
is it as straight forward as putting an ohms metre on the connections to test the circuit? Anyone done ht or can suggest any other way of testing it?
Old Jan 18, 2010 | 02:36 PM
ECU Monitor Enthusiast
What car/engine/ecu ?
Old Jan 18, 2010 | 03:06 PM
Patto's Avatar
Patto
its an 94 toyota celica gt4 has problems starting bad idle and runs pretty shite?
Old Jan 18, 2010 | 03:13 PM
Ahh ! Sorry I cant help you with exact technical information.
If it was a Ford then no problem..LOL
Probably better to ask on the Celica owners site as they will have done it all before !
Old Jan 18, 2010 | 03:15 PM
Patto's Avatar
Patto
yeah your probably right pal
Old Jan 18, 2010 | 08:38 PM
Patto's Avatar
Patto
bttt for any toyota fans
Old Jan 18, 2010 | 08:44 PM
ossie cossie's Avatar
ossie cossie
Toyota fans on a FORD site good luck.
on a side note Flux capacitor, how would you test the TPS on a big turbo escort cosworth. Just incase i ever get dramas with mine.
Old Jan 18, 2010 | 09:00 PM
Patto's Avatar
Patto
passionford caters for all usually lol
Old Jan 18, 2010 | 09:58 PM
t4 and greys's Avatar
t4 and greys
cosworth gimp
just not toymota,s as it seems
easiest way personally is buy a new one cheapskate surely cant be that much
Old Jan 18, 2010 | 10:18 PM
Andreas's Avatar
Andreas
Would probably need something that could show it in a graph or something? So that any deviations from the linear increase/decrease would be visible. Just guessing though.
Would a oscilloscope or whatever they are called work?
Old Jan 19, 2010 | 07:04 AM
Patto's Avatar
Patto
not my car so im not buying him a new one, i googled it and theres you tube vids them being tested with metres so i'll give it a go
Old Jan 19, 2010 | 07:19 AM
GTi-R23's Avatar
GTi-R23
The ladies love it French
Probably just a crude variable resistor, so as the throttle position changes, so does the resistance of the sensor so the ECU can work out at what position the throttle is.
So yeah, I'd try an Ohm meter first off to make sure it isn't open circuit.
Old Jan 19, 2010 | 07:59 AM
Spiky's Avatar
Spiky
the celica's have a sequence of fault lights, which tell you what is wrong, or has come up as an error
use google to search on how to do it
Old Jan 19, 2010 | 04:46 PM
Thats the best way measured at the ecu input pin
Excluding a small turbo escort cossie.....
The cossie TPS is not a straight forward poteniometer.
When at idle, the wiper does not make contact with the resistor.
As you apply movement, the wiper starts to touch one end of the resistor and then moves to the other like a normal potentiometer.
The outer pins are the resistor and can vary from about 1000 to 5000 ohms depending on type and age.
The escort will be around 4700 ohms.
The centre pin is the wiper and movement should cause a resistance increase on one outer pin and decrease on the other depending on direction and which outer pin you choose to test against.
Pin 17 on the weber ECU is the throttle input.
Use pin 11 as the earth for a voltmeter and oin 17 for positive.
4x4 vehicles (L8/P8) will have a voltage of about 0.1-0.5 volts at idle and 4.5 to 5.1 volts at full throttle.
2wd (L1/L6) will have a voltage of about 4.5 to 5.1 volts at idle and 0.1 to-0.5 volts a full throttle.
(Voltages given are rough taking into account measurement tolerances..etc)
Check the readings change smoothly when moving the throttle very slowly .
Any sudden jumps...change the sensor !
Assuming the Throttle butterfly and cable are ok, the best way to align the TPS to the throttle body is to loosen the 2 screws so the sensor is free to move by itself a bit and disconnect the loom.
Open teh throttle fully and allow it to snap shut by taking your foot of the pedal fast.
Then check the sensor rotates and springs back cleanly. Tignten screws, reconnect loom.
Hope that helps if only a breif explanation..lol
Old Jan 19, 2010 | 10:39 PM
ossie cossie
Thank you FLUX.
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
mike elsome
Sep 14, 2015 04:08 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
