Does anyone know why??
Old 18-01-2010 | 06:42 PM
  #41
I think they mean the bit left on the car is welded on ,block of wood and a big hammer to tweak the bracket forward to give you a few mm you need
Old 18-01-2010 | 06:51 PM
  #42
**caz**'s Avatar
**caz**
err liam, im not too sure what you mean, from what i could see the door went into the hinge with pins??
i might be wrong cos it wasn't me doing it lol
x
Old 18-01-2010 | 07:10 PM
  #43
liam-rst's Avatar
liam-rst
shit happens
x
the hinge come apart, i bit keeps a pin an i bit has a whole (male/female). did he open the door and undo 1 little torx bolt then lift it off
Old 18-01-2010 | 07:13 PM
  #44
ballin's Avatar
ballin
Originally Posted by BM08
If the door is for a mk6 escort then why would it not fit perfect?
fuck me you're a bright spark, wouldn't be much point her posting this if it did fit, would there.
Old 18-01-2010 | 07:14 PM
  #45
**caz**'s Avatar
**caz**
asked him... and got this reply!
nah didn't split it, just un done the bolts and remove it with my own strength lol
x
Old 18-01-2010 | 07:15 PM
  #46
**caz**'s Avatar
**caz**
x
Old 18-01-2010 | 07:39 PM
  #47
t4 and greys's Avatar
t4 and greys
cosworth gimp
answer has been posted by twins already caz ,and sorry if it offends but smashing the car,s hinges over slightly is best left to a man
well big lump hammers are heavy
welded parts both top and bottom need the gentle caress of a lump hammer and knocked in towards front of wing slightly !!!!
will need lots of trial fitting and removing to whack again .....
all i can assume it will be is that the shells have settled slightly differently or knowing fords one car was a friday afternoon job on the production line ,or your car or the car which the door came from has been in a prang at some time and wing welded on in slightly wrong position ....
hope you get it sorted caz
me personally hun with the car it is would do things slightly different
i would fit door as it is and use lump hammer on the leading edge of wing to smash it backwards
gap then would be sorted but you may then need another wing
Old 18-01-2010 | 07:48 PM
  #48
**caz**'s Avatar
**caz**
i cant picture how all that would work, but you guys know what ya talkin about! lol
i never had any of this problem with my mk3 fiesta when i had to replace that door...off with the old and on with the new..(well old but new to me and my car!) lol just wish this was as simple!
x
Old 18-01-2010 | 08:22 PM
  #49
t4 and greys
cosworth gimp
x
easiest way to explain is this picture the NEW door on the car ,with tight gap-quarter as you explained and a mahooosive gap to wing
now picture this the door is physically held in place by the 2 front hinges (which are welded to a pillar)
and also the door latch on the b pillar (inside door check on qtr)
so obviously the door needs the whole lot shifting towards the wing to even the gap out !!!!
the welded on hinges need knocking in towards the back part of the wing with the big gap !!
this in turn will even out the gap on qtr and wing
only problem now youve moved the door to suit is that the latch or striker plate may not catch the door now
this may need shimming out or spacing/packing with some washers to bring it out to the correct position !!!!!!
fookin ell hope you understand after all that am off for a beer now
anyway its not that difficult to sort if still stuck
just look for the dodgiest garage around and ask them to fit it!!!
will be done in no time im sure (NOT JOKING)
its called gypsy engineering .... brutal but soooo goood !!
Old 18-01-2010 | 08:34 PM
  #50
**caz**'s Avatar
**caz**
lol thats what i was worried about...obviously knocking it over so its closer to the wing, but then its pulling the door further from the latch...
enjoy ya beer! lol
x
Old 18-01-2010 | 08:50 PM
  #51
t4 and greys
cosworth gimp
glad you got it hun
if i was sexest and only around the corner would offer to come show you how to do it in a patrck swayze/demi moore ghost ,making clay type procedure ...... would be messy though .... oh and im on my 4th beer now
thats all feel drained now hahahahah
all seriousness though caz it will take a lot of time as if you knock hinges too far ,wing will have to come off to knock back the other way
(not much room to swing lump hammer in back of the wing
process will be whack, whack ....... ouch my fookin finger
fit door and check ...
whack,whack refit door and check
until its right
just dont watch unless you like crying and watching your car being abused sometimes best not too
if ya know what i mean
Old 18-01-2010 | 08:52 PM
  #52
TimC's Avatar
TimC
In my old place of work we used to have a special tool that went over the hinge, then with a bit of force you bent the hinge forwards or backwards to open or close the gap.
Old 18-01-2010 | 08:58 PM
  #53
t4 and greys
cosworth gimp
in my old place of work we used to have this guy who had a tool to do everything
right ******* he was
no just messin mate yes there is a tool to do it but im sure she wont have access to one to do it
anyway whats wrong with good ol british gypsy engineering then ???
have seen much worse done to cars on the production line as they being built ....
its fun seeing new cars on the production line being built having all the dints repaired and painted etc etc before they even been built
Old 18-01-2010 | 09:31 PM
  #54
furqall's Avatar
furqall
just re read it again an correct me if im wrong but your mate split the hinge to take the door off (left 1 part on car an 1 part on door) if so just need to loosen bit left on the car an theres your adjustment
there is no adjustment one part of the hinge is welded to the door and the other part is welded to the body
Old 18-01-2010 | 09:35 PM
  #55
**caz**'s Avatar
**caz**
thats what i thought, cos there is the bit on the door with the pins on and then the bit on the car....but hearing everyone saying different made me wonder if i was lookin at it wrong! lmao
x
Old 18-01-2010 | 09:47 PM
  #56
t4 and greys
cosworth gimp
hence the fookin big gypsy hammer and lots of expletives when you hit your hand doing it !!!
Old 18-01-2010 | 10:22 PM
  #57
cozzfather's Avatar
cozzfather
C.R.E.A.M.
thing is when your doing bodywork even with genuine parts stuff can line up shit,so you need to understand that twatting stuff and taking a shaving off bolt hole sometimes is the only answer,i find if you twat the hinges they can fit mint,same with bonnets that are adjusted on the bolts but still do not fit and won't line up you need to shove them over physically,i even have had genuine doors that stick out top and bottom and either side and you need to start using blocks of wood and bending the door to fit,if you loved your car and saw how a bodyshop has to make stuff fit you would not like it lol.
Old 18-01-2010 | 10:26 PM
  #58
furqall's Avatar
furqall
i agree whole heartedly
Old 18-01-2010 | 11:00 PM
  #59
Zetecfiesta's Avatar
Zetecfiesta
i agree with the hammer and wood method had to do this on both my replacment fiesta doors one was brand new other was second hand and same issue on my mates rs2k!
Old 19-01-2010 | 08:57 AM
  #60
**caz**'s Avatar
**caz**
Looks like im gonna have a bloody mission on my hands then...or someone else's hands cos i wont be able to do it lmfao
x
Old 19-01-2010 | 01:15 PM
  #61
TimC's Avatar
TimC
Aint that the truth.
My favorite was when you used to have to twist a bonnet by grabbing either side trying to get one side lower. The cracking noise as it went into shape was always weirdly satisfying
Old 19-01-2010 | 04:09 PM
  #62
cozzfather's Avatar
cozzfather
C.R.E.A.M.
i have seen cars getting twatted with everything from hammers to sledge hammers to transits and range rovers pulling a chain connected to a bent car to straighten them.
yeah jigs are great but some cars don't need jigging just a crafty pull if the dozers fooked
we once fixed a tranny hit up the arse by chaining it up and driving off,the van kicked its back end up about 4 ft in the air but fook me it come out perfect lol,it was hit on the m56 whilst sat stationary ouch!!
Old 21-01-2010 | 09:52 AM
  #63
**caz**'s Avatar
**caz**
Well im back to looking for another door now anyway!
Had a message last night to say that he had dropped the door and now bent the corner
so thanks all for your help but thats it now im back to keepin the rusty door again
x
Old 21-01-2010 | 10:13 AM
  #64
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
Check these guys out!
http://www.youtube.com/watch?v=tRX7E0yZxh0
Old 21-01-2010 | 12:32 PM
  #65
**caz**'s Avatar
**caz**
interesting watch! lol
x
