welders
Old Jan 11, 2010 | 07:28 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Default welders
Hi all, getting a defender 90 soon, so, due to it being a landy, I want to learn to weld. Also my dads 110 needs some welding doing to it, so I thought It'd be cheaper to learn n get my own welder. Heard clarke are quite good, and to go for one that can use gas and gasless wire. So what sort of power would I need for chassis/bodywork welding and can anyone recommend a good mig welder for a decent price?
Thanks, Sam
Old Jan 11, 2010 | 08:13 PM
TurboOsmond's Avatar
TurboOsmond
http://www.machinemart.co.uk/shop/pr...iy-mig-welders
this is the welder i use at home , its ideal for restoration and most types of welding you would do at home , welds up to 6mm mild steel witch covers welding chassis easly as well as being able to weld thin gauge steel
i wouldent use gasless wire tho , useing gas ( argoshield) gives a cleaner and stronger weld and reantal on a decent size cylinder from B.O.C. will only set you back a round Ł50-60 a year
iv had it nearly 6 years done 3 near compleat resorations and currently on my 4th with this welder and hasent missed a beat so long as you maintain it
and as for teaching you self to weld find your self pleanty of sheet metal, as youll need it and just keep practicing , be pacient and keep at it , it will come to you
start with puddel ( plug ) welds , then try doing a seam of weld , then lap welding to peaces together ( over laping ) and once you good at all thos try butt welding ( edge to edge ) , theres pleanty of infomation on the net about it mate to help you
as the saying goes " practice makes perfect !!!
Old Jan 11, 2010 | 09:33 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Thanks for the info mate
Old Jan 11, 2010 | 11:06 PM
2wdsaff's Avatar
2wdsaff
anybody can weld mate, just take your time and practice, most importantly make sure the bits your weldign are as clean as possible, cleaner the better and also make sure that you have a very good earth as close to the area your welding and you'll get a much better weld, surf the net or local library for books, bit of reading up and you'll be away, let usknow how you get along
mk22door
49
Mar 26, 2022 07:15 AM
Brian
Sep 11, 2015 08:06 AM
RS2000WRC
12
Dec 7, 2011 12:51 PM
Stavros
Feb 14, 2005 03:30 PM
powell
20
Nov 5, 2004 03:16 AM
