surround sound whats the best
as above really decorating at the moment new fire place ,tv,so while ive got the chance i can put a surround system in and hide all the cables so whats a good system ,nothing to fancy ,got a 46in samsung tv so some thing to complement this would be nice
jp
jp
can you smell purple?
Location: normally dewsbury west yorkshire, but i could wake up anywhere!
its all very discrete, all the wires hidden away and the only time you can tell its there is when its on.
all my kit is nearly 5 years old now (if not a bit older) and can still keep up with todays equipment. granted for the same amount of money you can fill a room with speakers but that isnt the point is it.
everything is crisp and clear and sound excellent. i "test drove" some other high end systems including a full bose system and to be honest i was just as impressed with the system i have now as apose to a system of 3 times the price.
ive got a bose acoustimass 6 surround system and a yamaha dsp-5 amplifier. the amp has EVERYTHING plugged into it, ps3, blu-ray, dvd, wii, tv, ipod, laptop.
most of todays cheaper systems are pretty good but in a year or two there out of date.
hope this helps.
if you have any more questions regarding this sort of thing please dont hesitate to ask.
im quite knowledgeable on how to setup etc.
p.s 6.1 and 7.1 digital systmes suck and are a waste if you ask me.
Amp wise I would go Onkyo all the way, best value for money and will leave a nice amount for some decent speakers. I have the double cube Bose Acoustimass speakers and a Mission Sub and very pleased with the sound (dont think the neighbours are though!!!!)
Audio specialist
i have a ROKSAN dsp surround pre-amp and krell power amps but i would guess you didnt want to spend 2K on a surround pre-amp then much more on power amps i run tannoy speakers they love to be driven and are amazingly punchy even at low levels, listen to me when i say NO-one can tell you what is the best its all down to what your ear prefers and your poket can stretch to. so get out to a few shops and get your listening head on.. good luck..
Lee
Lee
It all depends how much you want to spend, how discrete you want it to be, whether you want a same-brand system...etc.
For the money, the Sony systems are good. A bit more gets you Harman Kardon kit.
I agree with Lee - but the problem is finding somewhere that keeps of stock of stuff. John Lewis is useful to an extent, as are Richer Sounds.
Chris
Chris
Audio specialist
Can you get systems without cabling? I am sure I have seen them for sale using something like blutooth to talk to each other, or did I just dream it?
my first system when i was was 16 (11 years ago) the wiring cost as much as the amp, cd player and speakers!!!
the wiring will last you a lifetime, use these for 1 make systems. marantz amp - marantz cd player etc.
richer sounds!!!!
£1k can get you a stunning system that'll blow your socks off!
bose acoustimass 6 (£550) is what im using, 5 years down the line and its still running strong.
There is ABSOLUTELY no point having a wireless sound system - amps/speakers/cd-players don't run on thin air, they need power. So if you're going to run new power points for your remote wireless amps etc, why not run a line cable at the same time?
Also there is the issue of sound quality.
At audio frequencies, you will be hard-pressed to find a cable to affects frequency response even slightly (poor construction can affect noise and hence snr).
A wireless system has to fit a wide-bandwidth, wide-dynamic range signal (audio) into a narrow-bandwidth, shallow-dynamic range RF transmission. Some systems use analogue transmission, which curtail HF and LF response and compress the signal (domestic systems DON'T use decent companders to squash it then stretch it, like pro radio mics for example). Some systems are digital, which introduce noise and distortion by way of the conversion process.
If you're listening to MP3s it doesn't really matter.... If you're paying over a grand for a sound system, the quality achieved these days is high enough that you WILL notice the impact of a crappy wireless transmission system.
P.S. Blutooth can be used, but has VERY VERY bad bandwidth and dynamic range. It's designed for low-quality voice applications only.
Chris
Chris
go for an av receiver & connect your dvd/bluray sky etc into that, either get a speaker package or chose a couple of sets you like.
i have a soft spot for Denon stuff, i have a denon AV receiver running into a set of floorstanders, bookshelf rears, small sides (if i want 7.1) and an active sub, i run bluray (ps3) xbox360, denon ipod dock & sky through it, keeps me happy (for now)
Audio specialist
Chris
Chris
hope your well?
Personally I have a two channel ( stereo ) set up with a high quality 10" sub and it sounds 100 times better than most peoples 'surround' sound that i've heard as it's quality stuff, with quality cables/connectors, and well set up.
07-10-2015 12:56 PM
