New ford focus rs engine
Will this be the new high performance engine for the high performance ford scene in the coming will this be better than the old but proven yb cosworth engine?
I doubt that will happen and we good development i think 500+hp will be done.
A german tuning company claim that they have a 400 ps ford focus rs
http://www.mcchip-dkr.com/chiptuning...-focus-rs.html
Remember the new RS engine is the Volvo 5 cyl thats been around for years
Everthing is available for them if you look hard enough including steel liners
Guys in Sweden are getting well over 1000bhp from them now
http://www.youtube.com/watch?v=tZNST...rom=PL&index=1
DANISH cosworth abuser
The block HAS a problem, but that is AFTER ford have tried to take some weight out of it, therefore taking the strength out.
BUT it´s fixable with new thicker liners etc.
And yes, 850bhp + gas and over 1000bhp on racefuel
i think the main problem with the volvo engine will be the physical size of it... its massive so it wont be as easy to fit in anycar like the smaller yb?
the problem as you lot have said is its oiverborede the st,s are cracking at around 350
so why not just use the volvo motor in your st rs and see proper power from them
the liner is the problem, st uses a 2.3 rebored to 2.5 this creates a very thin liner.
as jacko said st engines normally expire 330 upwards.
the 2.3 volvo unit can go much further due to thicker liners.
the rs uses the same block as the st but has plasma lined liners iirc.
so should take more heat but upper limits ,who knows?
track.focus'd
12-08-2015 05:53 PM
