One for the Central Heating / Boiler experts!
Currently decorating the lounge and want to replace the manky old Honeywell Thermostat on the wall for a newer modern one.
Are the heating thermostats pretty much like for like or are they brand specific? I'd like to replace my current one (Honeywell) with this one:
http://www.heatmisershop.co.uk/produ...RT%252dTS.html
I'd like to think they are all the same but thought i'd double check! I have a conventional gas boiler (not a combi)
STOP!... Carry on
they are just a basic on/off style switch but temp dependant, so "should" be universal. i do believe that they are and have seen many different ones used on similar boilers, however i am not a boiler expert and only really seen a few. but personally i dont think there is much difference...
That's a programable room thermostat, far superior to a normal room stat as it also eliminates the need for a programmer.
To be able to use that you will need a neutral at the existing room stat, most room stats don't use a neutral but you may be lucky.
Check if you have 3 wires at the existing stat not counting the earth wire.
Most thermostats do have a neutral or they wont work, some honeywell ones dont have a neutral or if it has a battery it usually doesnt. Id recomemend this one ACL-Drayton (Invensys) Digistat + Room Thermostat(Reference #302046) (7th down on the page) if your just after a room stat, it doesnt req a neutral so will work if you have or have not got one or the 8th one down if you want a programmerble one, again doesnt req a neutral.
http://www.discountedheating.co.uk/s...ermostats.html
Chasing Radders
here you go......there are loads on the market but here is one for you to see
http://www.screwfix.com/prods/90334/...stat&source=aw
Not overly fussed about all the goodies on it as since i've lived here (a year now) i've probably only adjusted it a couple of times!!
rs220bhp - with the wiring I have unscrewed it off the wall, I have a red wire, yellow wire and blue wire going into the stat. None of them are earth, the earth screw (and one other) have no wires going into it? Any ideas, can take a pic if its easier? Dont think there is a battery anywhere.
Chris
Chris
Are these stats being recommended the ones that keep the heating all on all the time but just lower the temp overnight instead of shutting the boiler right off? It's supposed to be more fuel efficient to drop the temp a bit rather than switch it right off overnight and have to raise the temp again in the morning isn't it?
Chris
Chris
The wire going into number 3 will be your switched live and 4 and earth are empty? Is that right
Testing the future
DavidK
27-09-2015 02:55 PM
cossie09
10-09-2015 06:56 PM
