whats the best head gasket for cosworth
whats the best head gasket for my cosworth it is around 380 400 bhp used a grp a and comtic a lot ov people say small turbo escort what is best
thanxs
thanxs
As said wrc Mountune one ideally BUT only if the block and head faces are perfect otherwise stick to a Grp A gasket imo.
I believe the WRC one is even cheaper now ! not sure where I read that but I am sure someone was doing them for around Ł100
Monte 087
saff is working!!!...atm
S T Escos from Matt Lewis.....around Ł20......people gan on about using multi layered steel jobies, fine if ur engines in bits and u can skim the head n block......but in the everyday/real world u cant..........i'm running a st gasket at 430bhp
I got a Evo 5 now and your mate Jamie has been doing loads of work on it, he was telling me when you had your 5 and you put R888 on it and rang him saying you cannot get it sideways lol
is that with standard headbolts? wat boost are you holding with that ?
.....mine's 6 long stud, 4 std.....holding 28 psi......dont get me wrong when my engine was build i had it skimmed n decked and had a mountune multi on it.....but the head came off (turned out it didnt need to...).....so when i put it back together i put a s t escos gasket on cos they are more forgiving if everything isnt "perfect"....been fine
interesting, so if i was to use either a grp a or standard headgasket with a peak boost figure of around 30psi and holding about 26psi would it be wise to upgrade from standard headbolts? quite impressed the standard head bolts held 2.2bar on a wrc headgasket!!
il be aiming for about 380bhp
