easiest v8 conversion into sierra 3 door???
was on ebay there now and its umbelievable how cheap v8s are going for especially range rovers v8s
just wondering what would be involved in fitting lets say a range rover v8 into a 3 door sierra fabrication and parts etc........or is it even possible???hahah)
The kit came with engine mounts
Sump
Adapted Rover bell housing to fit a T5 (Rover boxes are crap)
Anti roll bar drop mounts which were not needed with a Cossie ARB
Crank spigot bearing (Reamed out Rover one to suit T5)
Exhaust manifolds.
The manifolds were crap and I sent them back and made my own, apart from this it's a nut and bolt job with the kit.
If you can find a TVT Rover to T5 bell housing it would save some agro.
Mark
cossie fan (unluckerly)
why bother lol yank shit just fit a yb with 350 up it!
Yes dont bother with a Rover V8 go for either a Ford 302/5.0 as these are similar size to the rover V8 but parts alot cheaper direct from the states or slightly dearer to buy a 351 Chevy SBC or mouse motor (small block chevy) but make sure its a 4 bolt mains version parts are same rough price as the SBF(small block Ford) and both if built right will Rev to 7000 and produce 500 bhp
why bother with a 5.0/302 built with all the right bits and full twin turbo 750bhp+ for about Ł3-4k, i'd much sooner have a crap 2.0 with 350 bhp!!!!!!!
rotating assembly Ł860
http://cgi.ebay.com/ebaymotors/SBF-3...Q5fCarQ5fParts
twin turbo full kit including turbos and intercooler Ł780
http://cgi.ebay.com/ebaymotors/FORD-...Q5fAccessories
Real Steel = not cheap in my opinion sorry !!! get a basic engine/block over here and import everything especially when exchange rate is right !!!
I brought back a pair of aluminium GT40 heads back the other year as my hand luggage pmsl !!
If you're doing it on a budget and want to go round corners stay away from the small block Chevy, it's much heavier than the 302 small block Ford
The 351 small block Ford is also a fair bit heavier.
XR8 engine bay pic
I bought a complete 5 litre Thunderbird for Ł300 (through a free adds paper)
Most of it got thrown away but it was a good price for a mint roller cam bottom end.
Mark
XR8 engine bay pic
Mark
Not forgetting the Shipping, Import duty and VAT on those figures.
Buy a CUT OUT from Real Steel and put that in first.
Then go for a built 5.0 later.
i did my homework and have a contact with a container of cars coming in a few times a year so shipping not an issue, duty and vat not bad, you just get the main parts from America and build over here.
if 750hp+ isn't enough,how about a short block 5.4 modular (same as the ford GT40 or GT500 mustang) for Ł3.5k+shipping/vat/duty, rated at 1500hp-2000hp!!!!!, getting all the right bits your could build a twin turbo 5.4 32v v8 including all duty/vat and shipping for about Ł10k http://www.modularmustangracing.com/...hortblocks.htm
here is a conversion that will interest some, its a 302 v8 twin turbo 4x4 using t56, and all in a sierra xr4ti or xr4i to us over here, it has the 8.8 axle fitted as well.http://home.comcast.net/~xr4x4ti/V8_AWD_Pictures.htm
where can i buy engine mounts for a 302 5.0 into a sierra 3 door?
would a standard cosworth differential be able to cope with power? or will it need uprated
Newer chevy LS2 in a sierra
3dr Cosworth owner
if you still want to use rover type stuff use the tvr v8. They are above 300bhp i think and go well. Got a mate with one it a land rover 90 and its quick
