ECU pin out data, Ford Escort 1.8Si 1997
Old Jan 4, 2010 | 12:22 PM
tim_ber's Avatar
tim_ber
Default ECU pin out data, Ford Escort 1.8Si 1997
Apparently you can get a sheet of paper which tells you all the readings of the pins on the ecu lead so that you simply test each output with a multimeter and if the readings are the same then you know that sensor is ok.
Do you know where to get this data sheet?
Thanks
Tim
matman
Sep 9, 2015 05:45 PM
dodge8283
27
Aug 19, 2015 08:42 AM
