Mondeo electrical help
Old Jan 2, 2010 | 03:38 PM
bluebirdjones's Avatar
bluebirdjones
Default Mondeo electrical help
Hi
I intend to hardwire a power accessory socket for devices like Sat nav, mobile phones etc. I am going to a run a 17 amp rated power cable from the battery positive connector with an inline fuse at the battery end.
My question is; Is there a suitable earth connector that I connect the negative cable to rather than connecting to the battery itself.
My car is a 2006 Mondeo Zetec 2.0 petrol UK version.
Thanks
Ian
Old Jan 2, 2010 | 03:57 PM
dug112y's Avatar
dug112y
passionford pro
yes anywhere on the chassis/shell is earth on a negative earth vehicle.
Old Jan 2, 2010 | 05:06 PM
TrevCos's Avatar
TrevCos
Yep, as said, anywhere on the body. On Escorts (probably similar to the Mondeo) if you take the footwell covers off there's plenty of holes where you can put a screw through with the earth cable with a ring connector on it and screw it to the body. Just make sure you don't screw into any other wiring and that the connection is as tight as it can be and Roberts your relation.
In fact you might find an earth point already set up that you can add an additional cable to, I tend not to do that though, because I don't want to risk upsetting stuff that's already there.
wowk
Mar 30, 2021 07:49 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
stevecfrst1
Sep 30, 2015 05:18 AM
The Enigma
Sep 29, 2015 10:31 AM
