Red chip keys
Old Dec 22, 2009 | 12:03 PM
RUBY123's Avatar
RUBY123
Default Red chip keys
Hello is it possible to program a new key with out going to ford i have the red key if that helps
Old Dec 22, 2009 | 12:11 PM
DangerousBryan's Avatar
DangerousBryan
yes. from what i remember. put the red key in the ignition,pats light should come on,take red key out asnd put new key in.
Old Dec 22, 2009 | 12:24 PM
cossiejay's Avatar
cossiejay
what car is it for
Old Dec 22, 2009 | 02:49 PM
RUBY123's Avatar
RUBY123
Thanks for the replys its for a transit
Old Dec 22, 2009 | 07:40 PM
As said with red key can defo program your new black ones, can't remember sequence, but bound to be on the web somewhere.
If done on fords machine, they can also delete any/all lost keys.
Old Dec 22, 2009 | 09:19 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you need 2 keys in some cases
Old Dec 22, 2009 | 09:40 PM
Moonie's Avatar
Moonie
  • Insert master key into ignition switch
  • Turn ignition to position 2
  • Wait until system LED illuminates
  • Switch off ignition and remove master key
  • Wait until LED illuminates again then goes out
  • Carry out the following within 10 seconds of the LED going out
  • Insert key to be programmed into ignition switch
  • Check LED flashes once to indicate correct programming
  • Switch ignition off. Remove key
  • Repeat complete procedure to program remaining keys
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
