just fitted a burtons hydraulic clutch kit
Old 18-12-2009, 05:52 PM
fostersice
fostersice's Avatar
Default just fitted a burtons hydraulic clutch kit
hi guys
just spent to day f ing around with the t5
i went down to burtons and picked ups some new parts for the car
t5 hydraulic clutch kit
new dust plate
hydraulic clutch hose kit
and 5 meters of blue silicon vacuun hose
so i rush home and get right to work
open the box and start to strip the gearbox down to fit the hydraulic kit
well there was no info on how to fit the kit or how it go's together
so i start with the box i remove to 4 bolt and remove the shaft cover
then put them togther and fine i need to remove the bearing cap thing and refit it to the new hydraulic clutch doonut thing
so ive done that and refitted the hydraulic doonut thing
then put the bell houseing back on and then fit the hydraulic push thing
then i start to fit the hydraulic hoses and they dont fit.;-(
so ive come in for a coffee and then gone back out to see what else i can do
well on looking at the gear box ive gone to move it and i put my hand on the shaft and it has some play in it????
i dont know if it was there before but i know everything in the gearbox is brand new
and everything i removed i re-fitted
should there be a little play in the shaft ??????
i just dont know if it was there before i started
Old 18-12-2009, 05:56 PM
mechanic28
mechanic28's Avatar
are you refering to the input shaft?if so then yes they do have a little bit of play
Old 18-12-2009, 06:01 PM
fostersice
fostersice's Avatar
Old 18-12-2009, 06:03 PM
fostersice
fostersice's Avatar
Old 18-12-2009, 06:07 PM
mechanic28
mechanic28's Avatar
nice daddy long legs mate is he your helper?
Old 18-12-2009, 06:16 PM
fostersice
fostersice's Avatar
Old 18-12-2009, 06:17 PM
fostersice
fostersice's Avatar
lol no he is just hanging around lol
Old 18-12-2009, 06:20 PM
Niall.b
Niall.b's Avatar
that looks neat
Old 18-12-2009, 06:21 PM
mechanic28
mechanic28's Avatar
does look nice and tidy fella!!
Touring Car Spares
Touring Car Spares's Avatar
Good looking adaptor kit , do yourself a favour tho and run a length of hose upto the bulkhead with a bleed nipple on it ( in place of the nipple on the kit ),save you pissing about under the car .
Old 18-12-2009, 06:29 PM
james kiely
james kiely's Avatar
how much did it cost for the kit mate?
cheers james
Old 18-12-2009, 06:32 PM
fostersice
fostersice's Avatar
Hose kit came with a bleed hose but it's the wrong screw size so need to fine somewhere that can change it or make one up for me
Old 18-12-2009, 06:35 PM
fostersice
fostersice's Avatar
The kit cost me Ł230
Ł35 for the hoses
and Ł35 for the dust plate
So looking forward to fitting it Monday and making the gearbox mount
It will only be temp as I will be making the exhaust so I have to have everything in place lol
Old 18-12-2009, 06:37 PM
james kiely
thanks for that mate
cheers james
Old 18-12-2009, 06:48 PM
Touring Car Spares
Time to get that adaptor plate over to CDF or Chassis 34 to copy then , its only a Saab ( or similar ) release bearing .
Old 18-12-2009, 06:59 PM
fostersice
fostersice's Avatar
Burtons wanted Ł175 for just the plate
I know pig has I brand new kit and a used push hydralic
And I have the code for my hydraulic
If it helps anyone lol
Old 18-12-2009, 07:32 PM
Richie.
aka Turbosailorboy
Richie.'s Avatar
Location: Under the water.... .......in a nuclear submarine
Top idea
I want one
Old 18-12-2009, 07:45 PM
-beefy-
formerly beefy-rst-2
-beefy-'s Avatar
ditto , get it over to mark asap !!!!!!
beef
Old 18-12-2009, 07:48 PM
fostersice
fostersice's Avatar
Or should I talk to burtons about a group buy????
Is that allowed
Old 18-12-2009, 07:53 PM
graham c
graham c's Avatar
no we just need that alloy plate making! and find which model that push center is
Old 18-12-2009, 08:02 PM
-beefy-
-beefy-'s Avatar
fuck burtons , robbing bastards ,
may your own kit up and sell it cheaper ,
to us
Old 18-12-2009, 08:14 PM
fostersice
fostersice's Avatar
Maybe fine someone who can do the alloy adaptor plate
I can get the push centre sorted
Old 18-12-2009, 08:17 PM
3dr
3dr's Avatar
Doesnt Martin at Reyland do a kit?
Old 18-12-2009, 08:19 PM
graham c
graham c's Avatar
found the push center just need the plate ?
Old 18-12-2009, 08:20 PM
fostersice
fostersice's Avatar
No only retroford and burtons do this kit
retroford gets it from burtons
Old 18-12-2009, 08:21 PM
fostersice
fostersice's Avatar
How much???
Old 18-12-2009, 08:39 PM
TONY C
TONY C's Avatar
yes we do, centre and side push
Old 18-12-2009, 08:47 PM
Tev
Tev's Avatar
Originally Posted by fostersice
How much???
Look on flea bay fella if i remember right ford cougars use a canter push they r bout Ł55
Old 18-12-2009, 08:53 PM
fostersice
fostersice's Avatar
Centre push is easy it's the adaptor plate lol
I've spent weeks trying to find someone who did the one I wanted
and burtons and retrofords was the only one I could find
Old 18-12-2009, 08:55 PM
fostersice
fostersice's Avatar
How much is your kit then as I called and was told u only do one kind
Old 19-12-2009, 12:25 AM
neilm
neilm's Avatar
I think you will find its the other way round.
Its a Retro Ford Kit and Burton re-sell it.
Talk to Dave at Retro Ford about a Group Buy - 01536 747978
Old 19-12-2009, 07:00 AM
andy escos
andy escos's Avatar
it looks a nice bit of kit but it will not fit your 4x4 box graham
Old 19-12-2009, 08:35 AM
graham c
graham c's Avatar
mines done !this is 4 a freind, if i can get the plate i can have it coped in a week easy
Old 19-12-2009, 09:50 AM
Retro Al
RWD IS KING
Retro Al's Avatar
The tilton one i had iirc didnt have a separate plate
Old 19-12-2009, 10:58 AM
graham c
graham c's Avatar
retrol al that looks like a landrover defender one ?
Old 19-12-2009, 12:43 PM
Retro Al
RWD IS KING
Retro Al's Avatar
The picture is from scrotes mk2, i bought the very same one from gpr raceware,its for a mustang and all you need to do is have the hole in your bellhousing machined by a few mm
Dead easy to fit aswell
Old 19-12-2009, 02:05 PM
graham c
graham c's Avatar
machined in which way?
Old 19-12-2009, 02:26 PM
Retro Al
RWD IS KING
Retro Al's Avatar
The back of the unit is slighty larger than the hole in the bellhousing thus the hole need making a little bit bigger
Old 19-12-2009, 02:59 PM
kjc300
kjc300's Avatar
IMO it's easier to centre push the 2wd.
4x4 is much easier to fit a normal slave cylinder due to the design of the 'bellhousing' (drill 3 holes in the bell housing, grind 3 webs off the gearbox and weld a nut onto the clutch arm).
Old 19-12-2009, 03:24 PM
-beefy-
-beefy-'s Avatar
see i knew i had a good reason for going rwd kev
Quick Reply: just fitted a burtons hydraulic clutch kit
