intercoolers
Old Dec 16, 2009 | 07:06 PM
gus's Avatar
gus
Default intercoolers
can you go too low with act temps
i could go ALOT bigger with my intercooler, so just wondering if you can over cool
Old Dec 16, 2009 | 07:09 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
never heard of "too low"....but then again u dont want freezing air.........
Old Dec 16, 2009 | 07:19 PM
turbotoaster's Avatar
turbotoaster
you cant overcool, that only happens if your on a carb when you freeze the fuel.
Your intercooler can only at best match the air temps outside it, go as big as you can, anyone who says it will cause lag is speaking poo aswell, your talking a very small difference in time from filling a small intercooler to filling a large one
Old Dec 16, 2009 | 07:31 PM
gus's Avatar
gus
after seeing andy g's cooler ( the thing is huge) i did think the bigger the cooler the better
Old Dec 16, 2009 | 07:42 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Yup, it can only cool as low as ambient, and the likelyhood of it getting that low is very low.
Old Dec 16, 2009 | 07:44 PM
turbotoaster
if you still feel they are to high, you have water injection
Old Dec 16, 2009 | 07:47 PM
gus's Avatar
gus
i have water injection anyway but its there as a 'if shit hits the fan kinda thing'
would rather have the intercooler work well enough
i have a evo v wrc core so that should be enough but as i say i can go alot bigger
so why not
Old Dec 16, 2009 | 07:52 PM
tommytxr's Avatar
tommytxr
why o why do i do it!!!!!
i think it was in fast ford the drag probe that can run inlet temps as low as 2c
Old Dec 16, 2009 | 07:54 PM
Gadget's Avatar
Gadget
Spanner monkey
I was always led to believe that there is an "optimum " act?? I thought is was 40 degrees?
Probably just chatting shit though, it has been said before!!
Old Dec 16, 2009 | 07:57 PM
gus's Avatar
gus
i think 40 degress is when you should activate the h20 as in getting tooo hot
sure some one will prove me wrong
Old Dec 16, 2009 | 08:20 PM
rstdave's Avatar
rstdave
I would have to agree there, anything over 40 and you'll start losing power not optimum.....in the winter my act's can drop to below 10 degrees if sat on the motorway for example and when they sit below 20 there is a marked improvement in the performance that i always notice anyway, car feels much sharper, snappier and pulls soo hard on boost! Get a biggen in there lol, if you think you really need it that is and as long as you're not blocking the rad of air?!
Old Dec 17, 2009 | 09:41 AM
Markb_s1's Avatar
Markb_s1
Does wind chill have any effect on ACTs?
I'm just wondering if potentially you could get temps below ambient if you were moving fast enough? I realise this sounds a bit odd!
Old Dec 17, 2009 | 12:22 PM
ECOS95's Avatar
ECOS95
Sounds feasible.
Old Dec 17, 2009 | 05:21 PM
Micky's Avatar
Micky
Originally Posted by ECOS95
Sounds feasible.
It aint feasible,it's wrong!!!! Wind chill only affects living creatures,not inamimate objests.You will never get the ACT temp BELOW ambiemt without using water injection,or spraying Co2/NOS onto the intercooler.Regards,Micky
Old Dec 17, 2009 | 06:39 PM
morph's Avatar
morph
Bigger will mean more pressure drop so more lag!
more to do with quality of the core rather than overall size.
and the most important factor if the air is actually getting to the cooler and out at the right speed.
too slow and you will have a higher act as the air passing through the cooler is not getting enough cooling
too quick and then the air will also get hot.
Old Dec 17, 2009 | 08:01 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Bang on mate, Theres no way, nomatter how fast the 'wind' is that you're going to cool below ambient without using something that'll 'chill' it.
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
