225/45/17 on the rear of a 2wd sapph
as title, who has fitted a 225/45/17 tyres on the rear of there 2wd cosworth, does it really make any difference to grip and handling and did they rub on a 25mm lowered set up, I have got 215's on the front.
Cake lover!
I have 235/40/17 on the back of my saph. The only time they rub is if i have a full boot and 2 people in the back, and i am booting it they just catch on the inner arch.
One of the best mods i did to the car was fitting the wider tyres. Loads more grip over the 215's i had on before, which were the same make and type.
I might be sounding a bit DIM here but what do you mean by 8j's ? if you mean rim width then they are 7"
also spoke to local tyre supplies and they said that if I'm going larger on the rear then I will need 225/40/17 on the back to keep the rolling radius the same something to do with width to side wall percentage????? that would mean that I would have a larger sidewall on the front, I have checked on the net and the tyre I'm looking at don't list a 225/40/17
I don't understand why he said this because i have 215/45/17 on it at the moment, if anyone can clear this up for me I would appreciate it.
Is yours lowered mate and are your arches rolled??
rich_bloor@hotmail.com
Puller of the Wrench
I have 235 on the back of my 3 door no problem. 8j
However I'd like to run some extra meat on the back of the saff as well - but with a 17x8 rim what offset should they be? My 3 door has ET32 so I'm guessing ET37 would be perfect on a Saff.
Cake lover!
I am on Koni's and Ahmed springs so only slightly lower than standard. You need an 7.5" rim min iirc to run 225 or 235 tyres. I would think that 45 profile over 40 will cause you some more problems due to them being that little bit taller.
10's can be fitted to a 3 dr if you trim all the kit back, this gives you atleast another 1.5" of clearence.
I was just trying to to get a better looking stance to it without changing the wheels I think that they have the standard 35 offset and as mentioned before 215/45/17 all round, but the rears look set back to far from the arch face for my liking could do with a slightly wider stance on the back, whats the views on spacing or is it not recommended for safety reasons if so what thickness would you boys suggest
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
