granada
Old Dec 14, 2009 | 04:03 PM
andym209's Avatar
andym209
Default granada
i wonder if any one can help me ive got a 1990 mark 3 series one granada 29 scorpio ive got no back brakes ive tried the peadal where the sensor is nothing my m8 was on a bout putting a new wire going through can that be done threres power going to the pedal but still nothing thanks andy
Old Dec 14, 2009 | 04:19 PM
Less.'s Avatar
Less.
having a mid life crisis
might be worth pming supramat2000 off here thinks thats his username he seems to know a lot about these
Old Dec 14, 2009 | 04:22 PM
Do you mean brake LIGHTS or the actual brakes themselves, bit confused.
Assuming it's the lights, then do a check by bridging the two wires together that go to the switch, if the lights work the switch is duff, if not then need to do a resistance/continuity test on the wire that goes from the switch to the rear brake lights, but yes as friend said if needed can replace the wire to sort out, though much more likely to be a connection problem.
This assume both bulbs are ok ?
Old Dec 14, 2009 | 05:28 PM
andym209's Avatar
andym209
yer proberly will have to get it sorted its got a small block chevy in now not a 29 but that would not affecet the brake wires would it its only happened sinnce its been stood for a week a wonder if its the damp
Old Dec 14, 2009 | 07:39 PM
Probably a dicky connection on the switch, I had a problem with my dads xr4i just after fitting tvr lump, every time brakes were used it blew the fuse, checked all the usual no shorts in sight anywhere, it was the ducting pipe we used that needed to run around and near the brake switch that was shorting it as the pedal was pressed, as it was a foil pipe, still easy fix!!
cliffy70
Sep 20, 2015 09:18 PM
Vacuman
16
Sep 3, 2015 06:26 AM
BillyCabrio
Oct 15, 2005 07:34 PM
frog
12
Aug 5, 2005 08:43 PM
TrickyDicky
Mar 7, 2005 08:54 PM
