Quaife pegged vernier pulleys
Has anyone used them?... i'm sure i've seen a few fitted and wondered what the differences are between them and say the Piper vernier pulleys? They're quite a bit cheaper and must be for a reason, lol! Maybe the adjustment is more coarse and harder to make the very fine changes?
These are the fellas... http://www.quaife.co.uk/Ford-Coswort...t-pulley-steel
They also do these in alloy, unlike others you have to accept the timing ending as near as possible, rather than where you want it to within 0 degrees out, seems pointless when the idea is the total adjustability, these are limited by the holes in cam versus pulleys, and not infinite like others.
i have the quaffe pullys on my yb, took me and a mate a while to time them up though, the pins are all off set to each other, think they look nice compared to the normal design verniers
Thanks for the response guys! Mark's building the engine and like anything he'll have the last say (when I previously mentioned them to him he hadn't used them before afaik), but just wanted to get people's views on here too!
Yeah I had a chat with Matt @ QEP when I was in there a while back. Look very nice in the flesh but pretty expensive being a true-lock pulley.
This is what i'm trying to clarify, whether the loss of adjustment will actually be worth worrying about... down to the mapper I suppose.
Thanks for that Chris, but your pulley shown is a true locking pulley which has similar adjustments to a regular vernier doesn't it, and obviously more expensive than the Quaife?
As for serious power... depends what your definition of 'serious' is lol... 450ish
Great pic there Claude, makes more sense now!
I guess it's just a question of whether Mark's happy with that adjustment level or not?... we'll see!
have you had a look at the cat cams pulleys Paul ?
http://www.catcams.co.uk/acatalog/Ford_Pulleys.html
Paul ,
With locking pin pulleys you will still get the fine adjustment .... I have made them before for Evo's
Unless you are going for some serious power there is no point,. they are a bit of overkill and will be much heavier.
The way it works is quite easy , the pulley part may have 20 holes drilled in it , 10 each side......something like 12 15 18.... and so on,
then the plate drilled at 13 , 17 ,21 degrees, and so on so when holes line up say hole 18 on the pulley and 21 on the plate means the postion is advance 3 degrees ,,.... if that makes sence
Tank Mike
Ford Focus ST Parts for Sale
18-05-2016 09:38 PM
