efi conversion engine sensors
Old Dec 6, 2009 | 06:25 PM
kevin john bird's Avatar
kevin john bird
Default efi conversion engine sensors
Hello all does any one know what engines sensors i need for efi conversion for my escort rs turbo any infro would be great if some could list them for me
Old Dec 6, 2009 | 06:30 PM
tommytxr's Avatar
tommytxr
why o why do i do it!!!!!
what ecu n inlet manifold are you going to use
studabear's Avatar
studabear
as above depends what system your going to use
tommytxr's Avatar
tommytxr
move this over to tech q and a's
Old Dec 6, 2009 | 06:36 PM
kevin john bird
Default escort rs turbo
Hello mate i be useing the fiesta rs turbo one got complete one of them injectors the lot just need to know what ones i need for the engine will be using ofab loom and ecu got them all connecters and map sensor co2 pot edis 4 etc just need to what engine sensors i need for the loom and engine.
Old Dec 6, 2009 | 06:46 PM
tommytxr's Avatar
tommytxr
if its a escort block you will hav to make up a crank pos sensor cos it dont hav a hole in the block, if you use a fiesta block its got the crank pos sensor hole in it.. The Inlet manifold as water temp, air temp sensors n you need a tps sensor, map sensor, co-pot sensor, o2 sensor, think thats it
Old Dec 6, 2009 | 07:05 PM
kevin john bird
Ok thanks mate what about the loom it has connecters are there any for the connecters.
Old Dec 6, 2009 | 07:26 PM
tommytxr's Avatar
tommytxr
2 way to do the loom you can use a ofab/ofac loom or a mk4/5 xr3i efi one the escort eri loom is easier to use you hav to change a few wires around on the ecu plug
manuel boeckx
13
Oct 3, 2015 02:29 PM
blackbeautyzetec
Sep 11, 2015 03:10 PM
EoinXR3
Sep 7, 2015 05:44 AM
Dahl88
Aug 22, 2015 08:16 PM
Zoggon
Aug 10, 2015 10:39 AM
