Removing the UJ/Coupling from the steering rack on a 2WD?
Changed the rack over on my 2WD but I'm trying to get the coupling that goes from the column to the rack off at the rack end. I've slackened off the bolt on the bracket of the coupling that tightens around the splined shaft on the rack, and hit it with a hammer, it looks like it should just slide off???It's pretty rusty so i've put some plus gas on it, but is there a pin or anything that holds this together that I'm not seeing???
Doh.....! Cheers, so it's like a ball joint, there's a profile for the bolt to go through, got it! Ah well, all that's left to do now is put the coupling on the car and the pipes and put on the track rod ends, shouldn't take long at all. Thanks for the help my man!!!!!
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
