Escort Diesel Van leaking fuel injectors?
My work Van is a Escort TD on a 'T' reg and it failed its MOT today because of a fuel leak.
Looks like two of the injectors are leaking as there is a puddle of fuel in the recess they sit in! lol
Is this a common fault, is it the injectors that needs changing, or is there a seal of some sort that can be replaced?
Cheers!
Cheers!
Team HOTHOT!
Odds on it won't be the injectors that are leaking - It will be the cotton coated leak-off pipes that are.
Easy to change - takes about 5 mins tops and you can either use some 3mm fuel hose or propper leak off pipes - doesn't matter either way (but the 3mm fuel hose is cheaper) as they are not under any pressure just the fact they perish with age.
They have a copper washer under each one, with age these go hard and it leaks under pressure(combustion).
You can either fit new ones, or just heat up your existing ones with a blowtorch till glowing red, this will re-anneal(soften) them.
