Xr4x4 shell (new)
Old 14-02-2016, 09:38 PM
  #41
Iain Mac
Iain Mac's Avatar
Rear ARB mounts are different. Not sure about the gearbox crossmember.
If you want to use the Sapphire loom the fuse box won't fit the bulkhead and you need to make an extra hole in the passenger footwell for the second big grommet or slice one, add the second grommet's cables into that, and you won't have wiring or a pump for the rear washwipe.
If you use the Mk1 loom, the engine loom is part of the main loom so you'll need to figure out wiring for the engine.
The Mk1 and Mk2 front doors are different on the window frame and for the interior handles etc. Not sure about the rears.
Old 17-02-2016, 10:28 PM
  #42
The Youth.
The Youth.'s Avatar
If it's a post 86 shell then the rear arb mounts are the same, same for the 2 holes for the wiring in the bulkhead
Steve
Old 17-02-2016, 10:46 PM
  #43
Iain Mac
Iain Mac's Avatar
Did they really change those for the last year of Mk1 production, or do you mean Mk2 shells have those changes?
bobsworth
77
24-03-2016 09:30 PM
gambo08
04-02-2016 10:49 PM
07-10-2015 12:56 PM
Fil
30-09-2015 12:08 PM
SMILER258
28-09-2015 09:04 AM
Quick Reply: Xr4x4 shell (new)
