which is best 2wd or 4wd throttle body,? or are they the same?
been through this before when i done cosworth management on my xr2 but was a while ago now and cant find anything with the search function so thought id ask again,
which is the better throttle body to use? 2wd or 4wd and also which is the better TPS to use as i remember there is 2 versions of that as well,
im using a different plenum cover so no need to worry about that side of it,
thanks marc
thanks marc
thanks marc
thanks marc
no sure about the best throttle body but i thought they where the same.
you will have to use the correct tps for what ever ecu you are using.
l8 4wd tps
l6 2wd tps
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
The PF09 Throttle Position Sensor will provide more accurate readings through the linear sweep than a PF01.
Should be easily calibrated for use with either T6 or F88 Marc.
The throttle bodies themselves are both of the same size, the only difference I recall on them is that the 2WD idle screw is secured with a 14mm locknut which needs slackening before the idle speed can be adjusted.
The 4WD unit uses an O-ring to secure and seal the screw which is recessed into the underside of the throttle body.
For a competition car you need to weigh up the pros and cons of easy adjustment on the 4WD one against the extra security of the locknut on the 2WD one.
Hope that helps
Hope that helps
