why does my CO alter itself ?????
Old Dec 29, 2004 | 10:18 AM
220TC's Avatar
220TC
Default why does my CO alter itself ?????
Hi,
I recently visited my tuner for a checkover and a power run but I am a bit confused about my CO on idle. It was quite low when I took it in so he upped it to about 3.5 I think but after every run on the rollers it was going back down to about 1.5 without us adjusting anything He said it was because I cleaned out all the combustion chambers when I did the headgasket change so it needs to build up the carbon again, does this sound right ? if not, what would cause my CO to change by itself ?
cheers, Duncan
Old Dec 29, 2004 | 11:57 AM
Stu @ M Developments's Avatar
PassionFords Creator
No its not, all you did there was drop the compression ratio very very slightly...
It depends what car your talking about, but il place a net on it being a small air leak with Bosch Ke Jetronic, like the diptick seal or the filler cap, cam cover gasket or sump seals a favourite...
Old Dec 29, 2004 | 12:02 PM
220TC's Avatar
220TC
yes its a s2 erst, you say it could be an airleak but how would that lower the fueling once we had manually turned it up on the metering head Could it be anything else ?
cheers, Duncan
Old Dec 29, 2004 | 12:17 PM
Because with a low vacuum reading the metering flap has no stability and will not return to eaxctly the same metering position twice after being subjected to any leverage.
It is VERY dependant on teh correct needle displacement and that requires a stable and repeatable vacuum.
Old Dec 29, 2004 | 12:30 PM
220TC's Avatar
220TC
so its just a matter of searching for the air leak and fixing it yes ?
........could a small air leak like the above cause the car to nearly stall when I dip the clutch at junctions ? (it will idle fine though )
Duncan
Old Dec 29, 2004 | 12:33 PM
Yes it will do EXACTLY that. 100%
To be honest, thats often caused by a suspect dump valve piston seat so if you have one, remove it.
Old Dec 29, 2004 | 12:44 PM
220TC's Avatar
220TC
ok cheers stu, I'll get looking
Neatrags
Aug 16, 2015 07:57 PM
kouzman
Jul 5, 2005 05:32 PM
Rhys
17
Apr 8, 2005 07:05 PM
