Rear licence plate LED lighting like new BMW's? *updated with pic of it finished*
#41
These Kev, 3rd ones down....
http://www.ultraleds.co.uk/automotiv...c-101_129.html
Hope your holders ain't mouldy green like my old ones were... Gave a green light
#43
#44
Mike - I found a genuine Ford set through a friend at Ford... They weren't cheap @ £12 each (as i had to get two) but came with holder+socket+bulb...
They were found on Microcat as 'Ford Licence Plate Lamp / Light Assembly' Finis code 6067427
They also were fitted to MK1/Mk2 XR2's and Mk3 escorts...
HTH
HTH
#46
HTH
HTH
Thanks
#48
Steve - third one down buddy
http://www.ultraleds.co.uk/ba9s-c-101_130.html
I ordered 4... one for front... one for back... and two for kickwell's on the front near speakers! They are all the same....
#51
The kickwell bulbs are the same as the licence plate ones (which are displayed in the link above i posted for Kev...)
Sorry for the confusion....
#53
Guys - ultraleds have a deal on this weekend!! Copied and pasted from the STOC
Ultraleds is having a pre-Christmas sale this weekend for orders placed after 4pm on Friday 4th December until Midnight on Sunday 6th December.
http://www.ultraleds.co.uk/automotive-bulbs-c-101.html
All orders using the code 67442 for 10% Discount (in the voucher/coupon box) when placing an order will received the discount (for orders £30 and over)
Thank you for Making 2009 our most successful year ever.
Ultraleds will be closed from 5pm on December 21st to 10am on Tuesday 5th January. Next day delivery and courier options will be suspended during the shutdown period.
Rich
Rich
#55
Update
bulbs may differ via 4x4 to 2wd
mark may have posted the wrong links for some of the leds for a 4x4 sapphire
the tower ones work 100% via the kick panels and back bumper lights
The front interior light is a festoon but i measure it at a 34mm bulb
the BA9/233 1W Wide Angled High Power Led Bulb Xenon White
will not fit the light unit as the bulb is located pushed in via the back the led is to big to fit the map lights
also the rear interior back light is not a festoon
its a 12v 10w 2A R10W
maybe the 2wd is different from the 4wd
smit do you have the invoice they sent you via email to help please
as i carnt find the bulbs for the interior to fit on there site
cheers
cheers
#56
Steve - IIRC yours is quite a late 4x4... I've gotta feeling they changed the front surround for late models?
My front interior holder looks nothing like that, has yours got electric sunroof?
The top of your 1st picture, the 2 twist in blubs fitted both my front and back interior lights.. The one by it's-self fitted the rear plate holders and kick-wells...
#61
A LOT cheaper on www.dealextreme.com
anyone wanting seriously bright interior lights, could od as I do, I stuck 2x 12 pad vivex led on the front interior light itself, £4.35 each, and one on the rear light.
I also converted my interior lights so that turning on the front interior light illuminates the rear, but turning on the rear does not illuminate the front one, so people in the back don't dazzle me unduly.
I also put one in my glovebox, the light is good enough to easily illuminate the floor around the outside of the car.
Anyone want to be REALLY different, how about rear and front number plate illumination, cheap and easy, carefully drill 4 - 5 holes in the edge of the plate, glue in a decent led, as the plate is acrylic, this light will spread over the whole plate, obviously use red on rear and white on front.
On the front you could have any other colour so long as fixed(not flashing) even blue is 100% legal, on the rear must be white.
The above is what I am doing as fed up with dim bulbs andc rappy number plate lights.
Use any voltage led, with resistor, and around 10,000MCD should do it, say 5 along the long adge and 1 at each end.
Resistor value can be determined easy by Vs-VF/ma
in english supply voltage 13.5 - 3v = 10.5/ 0.02 ma(miliamps) = 525ohm , so any resistor from around 450 - 600 will be fine, use 1/4 watt carbon film, cost around £1.50 for 1 HUNDRED, led's are pennies too.
I'm personally putting RGB(red green blue) in the front plate, you can either get 2 wire versions that change the colours slowly or fast, or ones with "common anode", so you can switch it from RGB as you like or all on if you like.
An idea I thought about for the rear one was as a extra brake light, ie run through another set of extreme brightness leds to come on with brake lights, I already have my fog/brake light mod which works brill for 20pence!!
Hope someone finds this useful.
#64
Looks sweet, I need some wedge bulbs for mine, they are the same as the sidelight bulbs, i think the stock must of changed on here
http://www.ultraleds.co.uk/501194t10...c-101_129.html
I cant find ones i want
#71
Team HOTHOT!
#72
Ed - I ordered these ones CLICK
#73
Ultraleds is having an Easter sale this weekend for orders placed online after 4pm on Thursday 1st April until Midnight on Monday 5th April.
All orders using the code 30225 (in the voucher/coupon box) when placing an order will received a 10% discount (for orders £30 and over)
jessie_rs
11
03-06-2019 04:57 PM
