silvertop oilpump
focusrrx87 looks like your building the same engine and spec as me.
are you using c20let pistons or forged?
forged rods i take it also.
im usins c20let and forged rods![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
i thing the standard oil pump with shit its self at 350bhp
im using accralite pistons 86.5mm and eagle forged steel rods.
iv been speaking 2 a few ppl with blacktop zetec turbos all around 350bhp al using standard oil pump.
dnt know if u found my thread in the foucs section but here's my spec list.
2.0 blacktop now rebored 2.1
t3/t4 turbo
obx turbo manifold
accralite forged pistons 86.5mm
eagle steel conrods
piper turbo cams
vernier pullys
piper cam bvelt
focus rs valve springs
new shims
port and polished head
rs1800i inlet manifold
st170 throttle body
pepperperformance plenum
p.e.c main bearings
p.e.c big end bearings
arp con rod bolts
arp head bolts
arp fly wheel bolts
focus rs gearbox with lsd
focus rs clucth
lightweight flywheel
focus rs spark plugs
magnicoil ignition leads
42lbs injectors siemans
rs500 intercooler?
oil feed and return
complete gasket set
de comp plate
new sump and cradle
new crank oil seals
new oil pump
pectel t2 ecu/ custom loom
t3/t4 turbo
obx turbo manifold
eagle steel conrods
piper turbo cams
vernier pullys
piper cam bvelt
new shims
st170 throttle body
p.e.c main bearings
arp con rod bolts
arp head bolts
arp fly wheel bolts
focus rs clucth
rs500 intercooler?
oil feed and return
complete gasket set
de comp plate
new sump and cradle
new crank oil seals
new oil pump
why decomp plate, dont your pistons have the correct comp ratio?
im using rover turbo inlet
c20let pistons
eagle rods
arp rod bolts and flywheel bolts
focus rs turbo ex mani
silvertop bored out to 2.1 and 2 breather ports
thats all so far![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
thats all i have so far
c20let pistons
eagle rods
thats all so far
gd question lol dnt know y it's on there, wot's ur budget and wot mangerment u using?
cheers anyway tho
hi mate silvertop oil pumps are prone to the cast internals of the pump failing due to harmonic distortion at 7500rpm and not the bhp figure . the failing of the oil pump is a major issue and will ruin your engine (just look at luca thread as it fooked his 2000 mile engine up) . there are 3 options mate
1 dont rev the engine over 7200 rpm and make sure you use a new genuine ford pump
2 take the standard pump , strip the internals out and get them machined out of forged material ( and sell them as theres nothing on the market at the minute and make yourself a few bob)
3 scrap the standard pump and fit a full dry sump system
the black top engine is a different story as you can buy billet oil gears for the standard pump which takes all the worry away , anyone interested in them contact austenw on here as he had them custom machined for his engine , and no they dont fit the standard silvertop pump before you ask.
they would cost no more than Ł100 in my opinion to get machined and would solve a massive problem with these pumps , so its worth the trouble if you know what i mean
hope this helps
cheers paul
hope this helps
cheers paul
I have been asking CFM of usa for a long time for the black top uprated billet gears but he said that they are getting a hard time getting them from there supplier also i contacted puma speed uk and the same problem ,it is a fact that all zetecs that rev more than 7200 rpm tend to break the oil pump gears so dont take any risks as it will ruin your engine , so i decided to go for a dry sump system
they only rev to 6750rpm standard rite??
so will 7000rpm be a safe limit?
a turbo'd engine will make most of it's power mid range then drop off so is there any point raising the rev limiter??
u can shoot me down now if ya want.![007](https://passionford.com/forum/images/smilies/bond.gif)
lmao!
lmao!
i think some people are getting mixed up the blacktop. cfm do the gears for the blacktop but not the silvertop.
and a blacktop will rev to 7200 all day and not smash the pump as thats what the rev limit is on a st170 and its the same pump.
my own engine has been hitting the limiter for the last 4.5k with no probs .
mk3ste
17-10-2021 10:09 AM
