alternators
Old Oct 27, 2009 | 11:44 AM
godrikki's Avatar
godrikki
Default alternators
would putting a 90 amp inplace of a 70 amp make a difference ie blow fuses etc
Old Oct 27, 2009 | 05:32 PM
godrikki's Avatar
godrikki
thanks john i dont think it will make a difference but seein as it aint my car and everywhere i phone asks if i want a 70 or a 90 i thought that some one on here would have a deffinate answer but as per usual everyone reads and dont reply
Old Oct 27, 2009 | 06:05 PM
cossytel's Avatar
cossytel
The current rating of the alternator relates to the maximum safe output current. The alternator will only supply the current that the electrical system requires so the bigger alternator alone should not cause problems. If you have added extra electrical equipment then the extra output may be useful but may cause problems with existing wiring which may overheat and eventually melt. The fuses are fitted to protect the cable and should not blow unless there is a fault or someone has fitted extra equipment to an existing circuit.
Old Oct 27, 2009 | 09:49 PM
cabriolet's Avatar
cabriolet
do them for a living fella we often supply higher output units of the same type it doesnt cause problems as already said the alternator will only supply what the car asks for unless u go to exremes
Old Oct 28, 2009 | 03:52 PM
Defo won't cause a problem(unless faulty), the rated amount is a max, that can be as short as 1 second, they absolutely will NOT run at anything remotely like their rating, a good guide is around 60% of rating as a continuous.
jonfoc
16
Sep 11, 2018 05:35 PM
steve.rst
Mar 15, 2016 08:01 AM
timsrs
22
Sep 24, 2015 08:14 PM
jay030787
Sep 18, 2015 04:38 PM
benw456
Sep 16, 2015 05:27 PM
