what size discs with fiat coupe turbo brembos on a mk 4 escort ?
as per title what size discs should I be using with the fiat coupe turbo brembos on a mk4 escort ? as I think on the fiat they are 284mm and the focus rs 324mm
3dr Cosworth owner
Fiat stud patterns are different mate if your thinking of using the discs of one of those. i know thats a popular upgrade with some of the vauxhall boys though
yeah i know the stud patterns are different mate, I was wondering what sizes of discs i could run with the fiat brembos calipers on a escort not what type or make of discs if that makes sense
suppose you could use either:
4x4 cossies discs (283mm iirc)
ST170 discs (300mm)
FRS discs (324mm)
the choice of disc will depend on the braket you have made up and the wheel size you are using.
ST170 discs (300mm)
FRS discs (324mm)
depends on yopur wheel size, id imagine you caould use any of these -
rst discs, 15" (14" at a push if on original rims or something!?)
cossie discs, st170 discs 16" (15" at a push!?)
frs discs, 17"
frs discs, 17"
muz
16-08-2015 12:57 PM
