Melted plug tip
Old Oct 21, 2009 | 05:51 PM
stevie.p22's Avatar
stevie.p22
Default Melted plug tip
My stage 3 saff has melted the tip of a denso ik31,been advised there is some detonation going on, could somebody tell me what I need to start changing/checking? Car was set up at msd about 6 months ago,cant really afford to go back over there as have just bought a house. Does anybody know of a reputable tuner in north yorkshire I can take it to have a look? Cheers
Old Oct 21, 2009 | 05:53 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Was it number 4 plug tip out of interest?
Old Oct 21, 2009 | 05:56 PM
stevie.p22's Avatar
stevie.p22
No mate it was number 2!
Old Oct 21, 2009 | 05:58 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Ahh - no more curiosity from me. Whip out the rest of your plugs and check the condition of them too
Old Oct 21, 2009 | 06:01 PM
RichieST's Avatar
RichieST
Faulty injector possibly, causing it to run lean in that cylinder?
Old Oct 21, 2009 | 06:08 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
You're lucky it just melted the plug and didnt wipe out the lot like mine did
Old Oct 21, 2009 | 06:15 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
lots of probable causes,
are you using happy shopper fuel?
Old Oct 21, 2009 | 06:20 PM
KSA-Cossie's Avatar
KSA-Cossie
If it was me i'd head back to MSD and they're 300odd miles away from me.
Old Oct 21, 2009 | 06:25 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
think u'd have been better off with ik27's to go with that power......ik31 arn't in the correct heat range.....
Old Oct 21, 2009 | 06:32 PM
pete mcrash
forgot to say has it done any other damage...??....cos when mine did the same thing it melted the piston and the tip scored the pot..........cost me a rebuild.....so hopefully u've been lucky
Old Oct 21, 2009 | 08:17 PM
stevie.p22's Avatar
stevie.p22
Not using happy shopper fuel,only optimax. Msd are a fair way from me too, but if I was going to have to travel far I would try Mark Shead this time. Pete, yes I believe they are the wrong plug for this spec, wish i'd have known at the time of purchasing. There doesn't seem to be any more damage done.... not sure where to go from here on
Old Oct 21, 2009 | 09:12 PM
godrikki's Avatar
godrikki
the nearest motor factors for the right plugs
Old Oct 21, 2009 | 09:23 PM
IK31 are ok in a stage 3, just they will foul easier than the hotter running IK27, normally fine unless around town all day long, they can start moaning.
Old Oct 25, 2009 | 11:07 AM
stevie.p22's Avatar
stevie.p22
Another thing that happens with the car, is when the car is on overrun going down a hill or incline etc, when you step back on the accelerator the car will missfire for a bit. It did this the other day, when I took the plugs out, plug number 2 (the one that has melted the tip) was covered in oil and had quite a bit of carbon build up. could this have something to do with the tip melting? I've put a set of 071's in that I had spare, and im just driving the car steady, trying not to put it under load or bring it onto boost etc
Old Oct 25, 2009 | 08:01 PM
Mark Shead's Avatar
Mark Shead
Get a leak down done and the bore checked with a scope.
Mark
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
