ofac codes
Old Oct 15, 2009 | 04:44 PM
benjaminsarmy's Avatar
benjaminsarmy
escort rst cosworth rep
Question ofac codes
hi can some one shed some light on the part no.s for the ofac ecu and map sensor as i may have the wrong ones ,
how do they match each other as my map makes the car run even if its not pluged in
Old Oct 15, 2009 | 04:56 PM
benjaminsarmy
help
Old Oct 15, 2009 | 05:05 PM
benjaminsarmy
is this correct as mine has a differnt code
and my map sensor has three wires with brown yellow wire in the middle should this wire be to the side insted of in the middle
Old Oct 15, 2009 | 05:34 PM
jonesymk2's Avatar
jonesymk2
what car are you putting the ecu and sensor into mate,the ecu is correct and the map sensor looks correct aswell
Old Oct 15, 2009 | 06:39 PM
gup's Avatar
gup
my ofac senser says v90fb-9f479-aa
did you check your fuel pressure and whats your c.0 readings
Fiddy
21
Sep 29, 2015 06:10 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
oilman
Sep 23, 2015 11:21 AM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
