Uprated caliper to use with standard 4x4 Cossie discs
You'll improve the brakes by fitting bigger disks on the standard caliper, if the standard calipers can warp standard size disks its not the calipers that aren't up to the job.
on the subject whats the biggest disc on std rims ?? or best disc caliper combo ? was just goin to upgrade to drilled n grooved with new pads on mine ?
cheers
gaz
cheers
gaz
Heat warps discs not calipers, 4 pots would be better as can absorb more heat and have more even pressure area.
The single piston calipers bind, this is why the pad wear is not the same on each side of the disc, so some effort is used merely to overcome the friction this creates, even alloy bells help massively, cast does not transfer heat anywhere near as well as alloy does.
jason_nike
18-08-2019 10:53 AM
track.focus'd
12-08-2015 05:53 PM
