Mk6 Escort.. help needed
Old Oct 13, 2009 | 08:05 PM
Mk1 Mex's Avatar
Mk1 Mex
Series One
Default Mk6 Escort.. help needed
Evenin all,
Just got rid of the parentals for the next six months (live abroad) and have been left thier escort to use as a run around...
Have just driven the car back to mine and oh my god if i'd known it was that bad i would have took it off tem early and sorted it out for them.
My questions are,
1) When i took my foot off the accelarator the car pulled to the right? Tracking OKish pulls a little nothing terrible. Poss steering rack?
2) Drivers side wheel locks up when braking heavy in the wet (ABS doesnt seem to kick in)..
3) How do you adjust the handbrake as doesnt work at all?
4) Engine doesnt idle right. Ticks over but is constantly up and down?
Think that'll do for now until i get it in the garage this weekend.
Your thoughts and views really help.
Thanks
Barney
Old Oct 13, 2009 | 08:13 PM
MJ_RST's Avatar
MJ_RST
Check tyres, pos worn lower arm, or pos sticky calliper
ABS fitted?? Light on?? as above, pos faulty calliper
10mm socket at the side of the handbrake lever. Sounds like it needs adjusted at the drums and pos a broken cable
Idle control valve, take it out, clean it or replace it
Old Oct 13, 2009 | 08:25 PM
Mk1 Mex's Avatar
Mk1 Mex
Series One
Cheers Mikey.....
Old Oct 13, 2009 | 08:48 PM
Top info above.This is what passion ford is about.
Rs_Motion
Escort MK 5 / MK 6
Jan 7, 2016 10:38 PM
col93saphcos
Aug 7, 2015 03:21 PM
